Washer stopped working
Yes I have a maytag washer and I was using it today an in the middle of the wash cycle it just stopped working never had any problems at all with it
  • 3 Answers
Timer got stuck ...may obe
2 fill sensor not responding properly(air bubble is in the way )
Posted on Jan 27, 2009
I went to use it today and it wasn't working properly. i set the laundry in, put in the detergent, closed the door and then deposited my money and selected the cycle. the machine ran for 1 minute then...
yes, your guess is most likely correct. Problems on the water supply into the drum of the washing machine. you can check the start of the tap water, hoses and water inlet valve Selenoid. Hopefully help.
Aug 18, 2010 | Maytag MAH21PDD Commercial Front-Load...
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
The Maytag top loader washer MAV7750BGW started to fill at the beginning of the washing cycle then stopped. Could not get it to do anything on any other cycle steps. Electrical supply OK. Managed to get...
It sounds like you have a lid switch problem. Check your the lid on your washer and see if it's not bent towards the middle. Often as things get sat on top, it will bend and not allow the switch to make contact. The washer doesn't do anything but fill when the machine thinks the lid is open. Try bending the middle of the lid back to where it is straight.
Jun 18, 2008 | Maytag Washing Machines
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Maytag stops at any cycle after warm
sounds like a motor problem. the motor might have reached then end of its life and is overheating causing the thermal overload protector to shut down the motor.
Sep 09, 2007 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
