Question about Sirius SU900 Stainless Steel
Sirius SU900 range hood turns on by itself
My fan and light turn on by itself. Could this be caused by my wifi network. I think it started about the same time I got the wifi. I do not have a remote control it was an option.
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I have a Sirius SUTC3536
The tapping noise is for a professional hood is usualy caused from the heavy duty cetrifugal fan. This fun is a metalic one and rotates in a metalic body. The most frequent reason for a tapping is from long time use it move from its place and heating the body. However in your case since it is brand new the fan to moved from its place it can be cause by a stong tapping of the whole hood and probably the fun brake in one point. So from the same shock a part from the damper as you mesion moved from its place and when the fan rotates makes it tapping.
Moreover in both case it might need a metal welding and since it is stainless steel need special argon welding and since it is new and it is cover from guarantee then we suggest kindly but intensive ask for the replacement of the unit, since it need to return to the factory for 100% noise free repair. In case someone try to fix it on site since is a heavy unit and nobody would like to accept the cost of remove it you will have the posbilty at anytime have the same tapping and even become worst. And worst thing this would happent one day after the one year guarantee and then who will pay the extra high labour cost for fixing it or replace it.
Posted on Aug 25, 2011
We have sirius 900 built in. Lights (both) stopped working and apper fine upon inspetion. Fan works fine. I can also hear the light switch click every time switch is depressed. Help. Thanks.
You need to trace the path of the current (voltage) Start at the light and work backwards. Check for 110Vac at the socket. If its there you have a bad bulb, if not keep going backwards towards the switch until you find 110Vac. When you find it the problem will be in between the last 2 points you checked.
Aug 13, 2014 | Sirius Hoods SIU3 90 SS Island Range Hood
#23350303200 Kenmore Elite Range hood - Range hood exhaust motor slows down
You have 2 windings in the motor that create a magnetic field. A winding is simply a coil of wire an they do not touch. when applying the voltage (turning on the fan) the windings create the mag. field causing the rotor to turn, which then of course turns the fan blade. When these windings get weak it causes them to heat up due to the resistance in the circuit and you there for loose ur mag. field... Or if the rotor starts getting restricted it will also heat up the windings an cause the fan to stop.. Time for a new venta hood....
Dec 01, 2011 | Kitchen Ranges
We have a sirius model sut900w/su900m built in range hood and all the sudden nothing works on it. Never had a problem for three years. lights nor the fans will work. Is there something on it we should...
the fuse on the unit may have broke or the breaker for the unit ay have tripped, check the breaker and if thats fine check the manual to see if there is a fuse and where it is located. If it is the fuse you can get a replacement at your local hardware store.
Jun 17, 2011 | Sirius Hood Built-in Powerpack, SU900
Hello, have a sirius range hood 600-cu.ft./min of power, 4-speed fan, electronic controls, halogen lighting. its not working at all. press controls, nothing, power is going to it, checked that. what you...
Check for power in and out of the main control board...sounds like the main board has fired...if you have power going in, but none coming out then the board is bad..
heatman101
May 02, 2011 | Sirius Hoods SU3
I have a Sirius range hood SU3. It sound like the right side of the fan blades are off-balance, because it's making a scraping noise. It is starting to get annoying. I looked at it and I don't see a way to...
Yes, I am on my third motor in a SU 4/ Sirius is brutal to deal with. All of the motors are **** and they are always back ordered. here in Canada the distributer change around 2008. They are through Maroline and a crappy company to deal with unlike the othe people in Oakville. Service sucks for such an expensive and beautiful stainless hood. Good luck and the motor does come off...
Jan 05, 2011 | Sirius Hoods SU3
Hood fan is turning on and off by itself, won't stay on or off.
What devices in the room were checked. A vent hood will sometimes run on what is called a humidistat, and anytime it senses high humidity it will kick the vent fan on. Check to see if this is the issue, if so and this hasn't happened before try changing the humidistat.
May 03, 2010 | Sirius Hoods SU3
Sirius hood fan maintenence
I do just spray with degreaser first then rinse off.
Then you can wash in the machine without worry of clogging up the unit.
Feb 27, 2010 | Sirius Hoods SIU401-22 SS Island Range...
Random fan speeds and light levels???
I have the same issue. Have to reset the breaker to make it stop. Bet it is a bad controller (design fault).
Nov 13, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Sirius SU900 Stainless Steel Logo
129 people viewed this question
Top Sirius Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
Zeagle
Level 1 Expert
ray gallant
Are you a Sirius Kitchen Range Expert? Answer questions, earn points and help others
