Question about Canon F-502 Calculator
How to clear memory on a F502g - Canon F-502 Calculator
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
On my Canon F502G, my a b/c button does not work from decimals to fractions. It will only go fractions to decimals. Is there something I can do to get it going?
If you convert a fraction to decimal and then just after do the opposite it will convert from decimal to fraction. But if you do some other calculations in between it may not do it.
Oct 30, 2013 | Canon F-502 Calculator
What does MC, MR, & MS mean?
Welcome to Fixya. Heres the meaning that you're looking for.
MC - Memory Clear. this clears all contents of the memory
MR - Memory Recall. This displays the current content in the memory
MS - Memory Save. This saves the current display to memory.
M+ - Memory Add. This adds the current figure to the value already present in memory.
Thanks for using Fixya.
May 12, 2011 | Office Equipment & Supplies
24-((24-(3/8*24))*2/3+((3/8*24))= on a cannon f502g is 5 yes or no?
It looks like you have more "open" parentheses than you have "close" parenthesis. You should make sure to put the last parenthesis in so that the whole equation is something like 24-((24-(3/8*24))*2/3+((3/8*24))) -- notice there are 3 parentheses at the end here.
Once you fix the error with the parenthesis, then it should give you 5 as the correct answer. http://www.wolframalpha.com/input/?i=24-%28%2824-%283%2F8*24%29%29*2%2F3%2B%28%283%2F8*24%29%29%29
Mar 01, 2011 | Canon F-502 Calculator
How to remove memory from scienfic calculator
To clear a memory location, just store 0 in it.
0 [STO] M clears memory M
0 [STO] A clears memory A
0 [STO] B clears memory B
etc.
Oct 13, 2010 | Casio FX-115ES Scientific Calculator
In use/memory light up and it won't let me fax.
To Clear the memory simply switch of the printer and power it on again. This will clear the data in the memory
May 25, 2010 | Office Equipment & Supplies
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Clearing memory Brother 8360p
Press quickly......MENU 2864 then press 91
Oct 16, 2008 | Brother FAX-8360P Plain Paper Laser
Memory full ux300
to clear memory(which i must warn will clear everthing) first press function then press the number 9,next press * (asterict) then press the number 8 then press the # key then 7 key, press start, you should see a ram version on screen,then press start again,next press # key untill it say's memory clear,press start and it should say memory clear.
Sep 23, 2007 | Sharp UX 108 Roll paper Thermal Fax
Canon F-502 Calculator Logo
47 people viewed this question
old marine
old marine
