Question about Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer in Platinum
Samsung topload washer is overfilling - Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer in Platinum
    Genius:
  • 1,669 Answers
The water level sensor is stuck or bad, replace it!
Posted on Jan 22, 2013
  • 4 more comments
  • Chris Jan 22, 2013
    Have replaced the pressure switch with a new air hose line and a new control board. It stops 3 inches from the tub ring. Is there a calibration for this model.
  • Leigh Perlmutter
    Leigh Perlmutter Jan 22, 2013
    There must be a level switch that turns off the intake solenoid that stops the flow of water.
  • Chris Jan 23, 2013
    The assigned technician could not find a problem, so I get to run troubleshooting in the morning on the unit. I will post what I find. Thanks for the insight.
  • Leigh Perlmutter
    Leigh Perlmutter Jan 23, 2013
    Good Luck!
  • Chris Jan 24, 2013
    I ended up finding that this model has a weight sensor on the bottom of the tub that senses the rise and fall of the tub with the weight of clothes and water. The pressure switch is solely a safety device to prevent flooding. At the factory they had placed a cable tie right at the module and stressed the wires. After pulling the component and examining the wiring harness, I found that 2 of the 6 wires had no continuity. Order and replaced the sensor and lower wiring harness. Good to go now!
  • Leigh Perlmutter
    Leigh Perlmutter Jan 24, 2013
    Nice troubleshooting!
Kenmore Elite Oasis topload washer overfills. I have replace the pressure switch hose but it did not solve the problem.
If you have gotten that far, you've done good.! I'd say to look at the painted screw on the pressure switch.. Needs to be turned. In clockwise direction to make sure diapham closes.. Or it's possible the circuit board is gone out..
Dec 02, 2016 | Kenmore Washing Machines
We just put a drain pump on a samsung top loader and since then it drains and spins but the clothes are stuck to the sides but are still wet.
When a washer is doing it's final spin, there is a short period when water is sprayed into the tub.
It sounds like your washer is spraying water into the tub, during its final spin, for a much longer time than usual
Aug 14, 2016 | Samsung 4.8 Cu. Ft. HighEfficiency TopLoad...
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Toploader washer fills with water then trips
Could be @ the point the heater comes on indicating faulty element, or Motor start indicating motor fault try on other functions to find out which
Oct 03, 2009 | Washing Machines
Maytag Neptune TL.
easy!the water pressure switch is not working the little hose going to it could blocked or off,or the pressure switch bottle could be blocked. rate me if right Eire
Dec 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer in Platinum Logo
142 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
