Question about Ingenico I6550 (6550US0041)
My old pin pad i6650screen black but green light on & i replaced new one but it said pin pad of line
What do i need to do ?
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
2003 Suzuki VL 1500 Intruder LC REAR DISC RATTLE,HOW DO I REPLACE IT?
Hello Dale, this is an easy job on your bike. Use a flat head screw driver and remove the brake pad cover...it will pop off.
Remove the hairpin type clips off of the ends of the brake pad pins.... Use pliers & pull the brake pad pins out from the front of the rear brake caliper....Clean the rear brake caliper's piston with brake cleaner. Use a rag and wipe it clean...Reinsert the old brake pads into the caliper. Place a pry bar between the brake pads, then push the inner piston into the caliper body, this will allow room to install new pads.... Remove the old brake pads...Coat the brake pad pins and the new brake pads metal back plates with high-temperature grease.
Slip the new brake pads into the rear brake caliper, then push the brake pad pins halfway into the caliper. Slip the spring clips into place between the brake pads and the brake pad pins. Push the brake pad pins completely through the rear brake caliper. Push the hairpin clips back into the brake pad pin tips. Snap the brake pad cover onto the top of the rear brake caliper....
Pump the rear brake pedal until the pedal feels firm, indicating that the brake pads have closed around the brake rotor...No bleeding will be needed because the system was never opened - That's all there is to it...i hope this information is helpful & good luck with your bike.
Nov 22, 2011 | 2003 Suzuki VL 1500 Intruder LC
Tolerance of ingenico i6550 to electrical fault
We have i6580's and they have a theft protection feature that if they get slammed the screen will go black but the green power light is on. When this happens they need to go back to the factory to be reset. If the green light is off and the screen is blank they are not getting power. Check the cable connections. Also, sometimes the USB cable gets damaged which will cause connection failure.
Apr 08, 2010 | Ingenico I6550 (6550US0041)
I'm just about to have a towbar fitted on a new car for a caravan. I am unsure whether to have a 13-pin socket fitted, as up till now our old caravan and car had just the 7-pin sort for the tailboard and...
Saves having to use a supplementary socket
01 Yellow Left Indicator
02 Blue Fog light
03 White Earth (35amp)
04 Green Right Indicator
05 Brown Right Side Light
06 Red Brake Lights
07 Black Left Side Light
08 Yellow Reversing Light
09 Green Permanent live
10 Blue Ignition live
11 Red Earth (35amp)
12 Black Coupled Trailers
13 White Earth (35 amp)
Aug 31, 2009 | 2007 Volkswagen Golf
Just wanting to find which wires go where on switch of fan with light. i have old wire to loop into with new old wire brown / black new black red & green Thanks
I think u mean old cable has 2 wires, those were brown & black, new cable has 3 wires those were black=Neutral, red=Phase go to switch, green=Ground.
Thats it.
Aug 21, 2009 | Monte Carlo 5BY52MW Bayshore Ceiling Fan
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Front brake pad replacement
black caliper and black caliper bracket = ATE (Teves), the other color is Akebono. To replace pads, use a screwdriver to stick into slot to pry caliper open a bit. Remove 2 caliper pins (under plastic caps on rubber caliper boots.) Lift caliper from rotor. Remove old pads. Wipe caliper anti-squeak onto back of new pads, and place pads into caliper. Replace caliper onto rotor and bracket. Insert pins and tighten securely (you can lubricate the pins) Replace plastic boot covers. Install wheels. Lower vehicle.
Jul 16, 2008 | 2000 Jeep Grand Cherokee
Ingenico I6550 (6550US0041) Logo
71 people viewed this question
Top Ingenico Computers & Internet Experts
David Payne
David Payne
richie46
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
