Orient btp -2002np will not take commands from register
Settings same as printers that do work. will print all set up info but will not allow communication from tills
SOURCE: my printer is hooked up
Not the printer...the FAX...won't go thru - comes back Phone Line Error
Posted on Sep 29, 2008
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
Posted on Nov 06, 2008
SOURCE: hp officejet pro l7680
SJAK00's solution is exactly right but here is more detail if you're like me and need step-by-step detail on how to find these tabs: Go to Control Panel and Open Printers and Faxes.
For the first setting change: Right click the printer you want to set the default printing preferences on. Click on Printing Preferences, then on the Advanced Tab the Printer Preferences will list Mirror Image, which probably says: "On"--click on this and choose "Off", then save the setting by pressing OK.
For the second setting change: Open the printer settings by double clicking on the computer in question. The printer screen (the one that shows the jobs in process) will come up and at the top click on Printer. Go again to Printing Preferences, and again switch the Mirror Image desigantion from "On" to "Off" and save it.
This worked for me. Jan
Posted on Feb 10, 2009
ENHESIS
  • 9 Answers
SOURCE: IBM 4610 TG4 Printer configurations from windows
Hi
you onli need send commands by excel is ASCII CODE its easy
Posted on Jun 12, 2009
SOURCE: how to download snbc btp-2002np usb driver
http://www.orient-technologies.com/drivers/Setup_BTP-2002NP_En%20V2.20.zip
Try to download from this website
Posted on Feb 01, 2011
Why is my printer printing in landscape mode when it is set to portrait mode?
Click File, Print, Then open the printer properties and make sure it is set to portrait. Also if you are working in MS office make sure to check the orientation tab. The document orientation tab overides the printer settings
Jul 18, 2014 | Canon Pixma MG5220 InkJet Printer
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
How to download snbc btp-2002np usb driver i have the cd but it won't let me open it sys file?
Download every driver from here: Driver Update. Great tool with user friendly interface. Wish you best of luck
Jan 10, 2010 | Office Equipment & Supplies
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
UNABLE TO PRINT LANDSCAPE
To print photos in landscape orientation use Irfanview. Install this software and use it to view photos. Very easy settings are available in print options from its options menu.
To print documents in landscape, choose landscape orientation from page layout.
For all other applications, set the orientation from the printer's properties inside the control panel in Windows.
Note: You cannot adjust it to print in landscape for direct copying from the printer's panel.
Dec 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Sanyo ECR 240 Cash Register
Hi. These are very rare, so I don't have info on them. However, Sanyo usually have a receipt on/off button on the machine if that model can have the paper turned off. Since it is a single roll printer, it may be set to journal mode where it will always print. To change this, you would need the programming tables. Do you have a manual for it? If I can check the tables, we can see if it has the on/off function.
Mark
Nov 07, 2008 | Casio Parts Cash Register PC Desktop
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
HP 7260 works fine with e-mails and documents. Does not print internet pages.
This sounds like an issue with your web browser. Which web browser are you using? Do you get any error message when you print? Also, when you print, make sure it is printing to the printer you think you have set up. The web browser will allow you to print to a different printer, then remember those settings.
You may also try this link in google:
http://www.google.com/search?hl=en&q=internet+explorer+cannot+print
Jan 01, 2008 | HP PhotoSmart 7260 InkJet Printer
107 people viewed this question
jasbo
jasbo
