Problem with HP pavillion ze4900 harddrive. bios says no IDE device when trying to find hard drive.
No operating system. windows xp will not load. Bios says no IDE device. What should i do.
    Novelist:
  • 153 Answers
You can try to boot from CD/DVD drive with XP cd to see if the install program can find the hard drive. Try to use default setting in the BIOS.
Sounds to me like your hard drive crashed. I had one that did this and same thing. You can either replace the hard drive, use an external hard drive/flash drive (load the os and download laptop drivers) or use a cd based OS like Knoppix.
If you need help with the XP CD let me know.
I hope this helps!!!
Posted on Jan 22, 2013
  • 110 Answers
SOURCE: Bad Harddrive
Can you just clarify that you installed XP with the new IDE drive installed in the notebook and that you have selected disc 0 in the bios as IDE and that it is aslo set to boot from that drive?
What you are describing also fits the symptoms of installing XP on a SATA drive without installing SATA drivers first. (XP doesn't install SATA drivers, Vista does.)
So this does sound like a bios setting issue
Posted on Apr 11, 2008
rajak2009
  • 527 Answers
SOURCE: new hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 09, 2009
  • 7993 Answers
SOURCE: I loaded a new, formatted IDE hard drive into an
If IDE drives are hooked to the same controller one must be configured in BIOS as Master, and the second as slave.
If there is only one drive, it should be set as master: Two drives on two different controller must be both defined as master.
Hope it helps.
Posted on Sep 07, 2009
  • 4090 Answers
SOURCE: I loaded a new, Windows XP formatted IDE in a 570e-then nothing
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Testimonial: "Good advice, "
ftw1952
  • 10319 Answers
SOURCE: HArd drive issue. Self diagnostic desnot recognise the hard drive
Was the replacement hard drive a new one? If not it will have to be formatted first
Posted on Jul 18, 2010
REPLACING HP PAVILLION ELITE E210Y HARD DRIVE WITH 2 TB HARDDRIVE CAN i DO THIS?
Yes you can, for hard drives larger than 2TB you will need a 64 bit operational system like Windows 7, XP recognizes hard drives up to 2TB.
Jun 29, 2014 | HP Pavilion Elite M9150F Desktop PC
Pavillion P6000 won't recognize any drives
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Jumper settings
If you try to enter in safe mode or at last known config and the laptop reboots or freezes then you need to reinstall the operating system if you want to use that hard drive on hp pavilion a1000n. The laptops have different chipset and XP requires to be the same or similar chipset to boot properly.
Oct 06, 2009 | Maxtor Hard Drive
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
I am facing Problem installing Windows XP with Asus P5RD1-VM series mothboard with SATA Hard drive. My harddrive doesn't get detected while installing Windows XP. While going for coping files for...
I would go into the BIOS and make sure your SATA controller is using the AHCI or IDE setting and not RAID, if it is using RAID then it may need to load a special driver to install windows.
This is the most likely cause of your problem, can you also check and make sure the bios is seeing the HDD at all?
Jan 21, 2009 | Microsoft Windows XP Professional With...
Ide install problem
there may be some conflict in the jumper settings so just check the jumpers and try to connect it should detect the device ...
if you still persist the problem then just check the ide bus cable there may be some problem in that ...
replace the ide cable and try it ... make sure that the ide slot is working properly ...
regards
-Dileep
Dec 26, 2008 | Asrock AM2NF3-VSTA (4711140874470)...
Bad Harddrive
please check your cables and try with new one.check the bios setting
Apr 04, 2008 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
David Payne
David Payne
