Question about Uniden Lands Phones
How do I silence the handset ring on a Uniden cordless phone
My Magic jack already rings so I do not need the uniden handset ringtone. How do I silence it?
3 Suggested Answers
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 102366 Answers
SOURCE: Problem with Uniden D1680 Cordless Phone I have a
Press MENU/SELECT to bring up the menu. Select "Ans. Setup". Select "Ring Time".
The above is condensed from this manual.
Posted on Oct 10, 2011
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
How do I set the # of rings on my cordless Uniden phone?
Select the model of your Uniden DECT 6.0 phone from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jul 16, 2014 | Uniden DECT 6.0 Cordless Telephone...
How to take uniden cordless phone off silence
Since you didn't specify the model of your Uniden cordless phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Feb 03, 2013 | Uniden Lands Phones
How do I change the ring tone on my uniden dect 6.0?
1:Press menu/select button
2:Press handset setup
3:Press bottom button down to ringtones, you have 6-8 options
:)hope this helps:)
Jul 23, 2012 | Uniden DECT 6.0 Cordless Phone ID
Uniden 5.8 cordless phone - replaced batteries, but now the phones don't ring....help?
up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Uniden Cordless Phone
How do i set the ringtone on my Dect6.0? Thank you
firstly, goto menu on your phone. then, goto setting and lastly,. goto ringing tone to select a ringing to of your choice
Jun 02, 2010 | Uniden DECT 6.0 Cordless Telephone...
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Uniden 5.8Ghz phone.
Jan 20, 2008 | Uniden Cordless Phone
Lands Phones Logo
44 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
