Question about Paragon Kitchen Appliances - Others
Model nomber is UE40010 serial number U08 need new plastic gear and shaft
Gear teath are stripped
ginko
  • 19396 Answers
SOURCE: GE WASHER MODEL NUMBER WHDSR316GOWW,
Here you find all parts for your appliance.
Click on the diagrams to get the exploded view.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: Fellowes shredder crc 32080 plastic gear stripped,
Made in China..same as made in Japan 50 years ago...junk...Thank the big box stores for the ****..Best Buy, Wallmart, Staples and don't forget your new job at McDonalds........
I bought an INIT tore up a gear also JUNK JUNK JUNK
Everyone of them will telll you parts UNAVAILABLE>>>>>>>>>>>
Posted on Aug 05, 2009
  • 496 Answers
SOURCE: Good afternoon,
Hi Roy,
Here is a toll free number to DTX International. With the model and serial info, I'm sure they can assist you in a replacement part:
DTX International
9855 North Front St Mancelona, MI 49659
1-800-665-0728
Hope this helps... Good luck!
Posted on Sep 22, 2009
philschneide
  • 448 Answers
SOURCE: Stripped plastic coupler on output shaft of Dremel model 277
I'm guessing, but I think that the Sears tool uses the same flexible coupling. If you go to www.searspartsdirect.com and put in the model 572610031, you can look at the diagram and decide for yourself. I think the part costs $2.57. If it's the right one, I'd order two or three for the future.
Hope this helps.
Posted on Oct 06, 2009
jsrock516
  • 5911 Answers
SOURCE: sharp carousel model number R-930ak + parts The
This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
For the model number you have listed, the part number is 46-841666-3.
You can purchase replacement parts at searspartsdirect.com.
The site also offers helpful exploded view diagrams to assist you in parts location/identification. The motor is listed at item 001-20 under the "Cabinet" heading. If you have any questions, please post back and let me know. I hope this helps you.
NOTE: You also consider the turn table coupling, which is item 004-22. The underside of the coupling has a keyed slot that fits on to the turn table motor shaft. If the coupling becomes cracked, or if the keyed slot "rounds out", it may be slipping on the motor shaft and not turning.
Posted on Dec 17, 2009
I need replacement plastic guides on the metal shaft between the gears. How do I order them?
You will need to get the model and serial numbers to order parts.
May 25, 2016 | Washing Machines
Fix paper shredder
The problem is usually shattered plastic gears inside if the motor works but the shredder blades don't. My shredder has two shredded cogs. Getting replacements is not easy. The companies that sell these types of cogs, don't want to sell singly. If they were 10 bucks each, it is cheaper than buying a new shredder. There are YouTube videos on how to repair them with metal strips or epoxy adhesive.
Fellowes is a good make, so contact them direct.
Authorized Service Dealers Fellowes
Feb 20, 2016 | Fellowes Office Equipment & Supplies
The chain sprocket does not move but the moter runs
I think you need to replace the drive gear. look inside the main housing. if you see white plastic shavings that would confirm the gears are stripped.
kits are available for under $25.00. don't buy the one with just the gears, get the new shaft sprocket etc.
Not a difficult repair. However, be sure to follow the instructions carefully. the position of the chain & sprocket when you put it back together do matter.
Good Luck
Steve
Mar 02, 2015 | Sears Craftsman LiftMaster Chamberlain...
The plastic gears in the gear motor are stripped out where can I find parts for it Its a model ue40010
These gears are used in many of the 8oz poppers: http://www.keepitpoppin.com/popcorn-machine-parts/motor-gearbox-8oz.html
Feb 10, 2011 | Lincoln Roosevelt Popcorn Maker
Model No MH6150MXQ - 0 Turn table will not
Hello- The motor has a plastic gear on the shaft that turns glass tray. These can crack or slip off the shaft and not engage the slots on tray. Check to see if gear is cracked or stripped. It may just be loose. Anyway, this part is less than 10$, so replace if it's bad. Let me know if this solves the problem. Have more info if needed-  Thanks- Ed
Mar 18, 2010 | Ovens
Good afternoon, I purchased a Roosevelt 8 ounce corn popper about 1-1/2 years ago. It is used once a week for approximately 1 hour. The heating element has failed and I am trying to purchase either a new...
Hi Roy,
DTX International
1-800-665-0728
Sep 22, 2009 | Lincoln Roosevelt Popcorn Maker
A drive gear seems to slipping when the blade cuts into thicker s
Yes you can get parts for it.The gears tend to strip the teeth.
Jul 06, 2009 | Homelite Expand-It Hedge Trimmer...
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Can't find part number
I would like you to find the bar code on your shredder. Once you find the bar code label look right under the bar code strip and get the numbers. It is a serial number.
Apr 14, 2008 | Office Equipment & Supplies
Kitchen Appliances - Others Logo
54 people viewed this question
Top Paragon Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Paragon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
