Question about Maytag EPIC MFW9700S Front Load Washer
F2 flashes after about 10 min after starting a load
F2 flashes on every load on my matag front loaded washer
I was have the same issue. F2 is a drain issue according to the book. Called and scheduled a repair for Friday. The good news is, this is an easy fix that I did myself in about 15 minutes total time.
You need to remove the front lower cover, held on by three 7mm nut/screws. I had to use a small but long extension on my ratchet to get a decent hold on these screws. Once the screws are off, pull the front lower cover off. Directly in the middle you will see a screw cap, similar to one you would find on your gas tank on your car. WARNING!!!! WHEN YOU REMOVE THIS, EXPECT A BUNCH OF VERY NASTY WATER TO EXIT. Have numerous towels close at hand and do not sit on the floor in front of the machine when you unscrew this cap to the left. The cap is also a filter and you will find things in there better not described, but it is safe to say, once you see whati s in this filter, you will know why your machine would not drain. Clean the filter, put it back on tight and button up the front cover. Your ready to go.
I just completed the process described above and have just completed the second load without issue. I am doing the happy dance and saved myself a few bucks. Tomorrow, I cancel the repair appointment.
Good Luck!
Babycakes Galliher
Posted on Jan 29, 2009
  1. Open the front door of the washer, and run your hand behind the big, gray rubber gasket. You might feel/see small items stuck there.
  2. If you kneel in front of the washer and look along the very bottom edge, you'll see 3 screws in a row. They are of the "torx" type. Unscrew them and then jiggle out the bottom panel. Inside you'll see a large plastic (off-white color) drain, and you can unscrew the 3-inch diameter cap off it and pull it out. The backside of the cap is a filter. Clear it out and put it back in. (We found a baby sock there).
Posted on Jan 28, 2009
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
The Matag Neptune Washer unit will not do a spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front load washer keeps shutting off during the wash cycles. Any idea as to what is wrong and how to fix?
my matag neptune front load washer keeps shutting off durning the wash cycles,and the letters LP keep appearing.Any idea as to what is wrong and how to fix it?
May 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Flashinf H F
check your fill hoses,,for kinks,,or clogged,,the unit is detecting no water ate one or booth of the fill hoses..clean your screens,,,onthejob
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
