Question about Sanyo PLC XU32 Multimedia Projector
Macbook compatibilty with Sanyo PLC-XU32 projector
I can't get the projector to work using my apple laptop.  The screen just says 'no signal'.  If I connect it to a PC it works straight away.  It's connected with a standard Apple adapter that has been fine with other projectors.  The Apple seems to recognise the projector as the screen adjusts itself as it does with other projectors.
Yours hopefully,
David Middlmiss
    Champion:
  • 205 Answers
Force the frequency on the mac to 60hz. The projector can't respond to the high clock rate of the mac. Contact sanyo for a firmware upgrade to this product as well
Posted on Jul 07, 2009
  • 600 Answers
Try going to the displays section in system prefs, with it all plugged in and powered up click the "detect displays" button and it should be there
Posted on Aug 20, 2009
  • 32 Answers
David, a bit more please. What type of connection? VGA? DV? and at what resolution?
Posted on Jul 10, 2009
  • 22 Answers
Check your resolution is set correctly.
Marc Engineer
Posted on Jun 17, 2009
4 Suggested Answers
Fusiondc
  • 47 Answers
SOURCE: USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Posted on Jan 17, 2008
SOURCE: Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
Posted on Feb 13, 2009
Master Rod
  • 7 Answers
SOURCE: Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Posted on May 08, 2009
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
Connecting sanyo pro xtrax multiverse projector to a Macbook pro
VGA to HDMI cables don't work. They're a con. VGA is an analogue signal. HDMI is digital. It's not possible to convert from one to the other with just a bit of wire.
Sep 02, 2014 | Sanyo PLC-XU101 Projector
Sanyo plc sw20a dose not work with my laptop what
you need to activate the external monitor port on your laptop.
Oct 04, 2009 | Sanyo PLC SW20A Multimedia Projector
Dell 3400mp not getting signal from Macbook
If you were using the Apple S-video adapter to connect to your Dell projector, please realize that MacBook models with NVIDIA graphics cards do not support this adapter. Otherwise, please be more specific about what model Mac you have and what adapter cable you are using.
Aug 24, 2009 | Apple MacBook Pro Notebook
Can you connect a Mac ProBook laptop to a ProxTrax Multiverse?
Hello. There is no "device" needed to connect the units together...You'll need a cable that is"mini display port to vga". In order to connect the projector to the laptop, the cable has to have the special Apple connector which fits into a specific socket on the back of the laptop. The other end is just a standard vga connector which is plugged into the computer input on the projector. Hope I helped you!
Aug 20, 2009 | Sanyo PLC XU35 Multimedia Projector
My Pro-X won't communicate with my computer
The first check is to make sure that it does accept other VGA signals into the 15pin D connector use 800X600 resolution, if signals are present then it is because you need to configure the output reference on your laptop.This is by using the F keys etc this switches the VGA XGA signals from your laptop screen and reference's it out to the connector.Kind regards J Williams www.jvsvisual.com
Jun 13, 2009 | Sanyo PLC-SW30 Multimedia Projector
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU32 Multimedia Projector Logo
408 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
