Question about Gaggenau Refrigerators
Need URGENT Repair service in Marbella Spain for Gaggenau 1K-300
Do you have a contact number please it is urgent the fridge is off and everything will spoil. Plus the freezer has a limited capacity and we cannot find any rekiable service facility for Gaggenau in marbella or Fuengirola or even Malaga or Puerto Banus.
SOURCE: fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Posted on Nov 17, 2008
Healeyman
  • 1198 Answers
SOURCE: Need a wiring diagram for a Hotpoint fridge freezer
Check Repairclinic.com, it's a good site.
Posted on Apr 27, 2009
  • 93 Answers
SOURCE: my refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
Posted on Sep 11, 2009
woodchuck789
  • 4070 Answers
SOURCE: fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Mar 11, 2010
Testimonial: "Thanks, I have checked that, but the vent at the bottom of the fridge section is a rigid plastic grill, which doesn't, nor looks like it should move. "
  • 670 Answers
SOURCE: I have a Westinghouse frostfree
I am not sure if your freezer is working correctly if the fridge compartment is not at the right temperature. The way refrigerators work is that the fridge compartment is indirectly cooled by the freezer. The evaporator coils that cool the freezer, also cool the refrigerator. There is a fan in the freezer section that draws air from the refrigerator and blow them over the coils. The vent to the refrigerator could be blocked by debris or ice build up if the defrost circuit has failed. In order to check, you need to remove the back panel from the freezer section to check the condition of the coils/vent. Also check the fan in the freezer and see if it is operating. If the coil is encased in ice, then the defrost circuit has failed and that needs to be fixed otherwise the freezer will not cool to the correct temperature.
The way the defrost circuit worksis that normally the compressor has power for 8 hours, then the timer cuts power off and sends power to the defrost heater for about 45 minutes. The heater is attached to the coil and warms up the coil to melt the ice. When the coil reaches about 40 deg F, the thermostat which is in series with the heater, opens up cutting off power to the heater. This prevents the freezer from getting too hot. After the 45 minutes are up, the timer switches the power back to the compressor again to restart the 8 hour cooling cycle.
Any of the three components can fail causing you not to get the defrost cycle to work. Typically the timer stops advancing so you either stay in permanent cooling or defrost mode. Or the heater burns out so it can
Posted on Mar 13, 2011
Testimonial: "didnt know where to start at first, but this was enough info to help me out and fix the fridge. thanks."
Printer is not working. caution machine trouble service call c13851 error display
You really need to call the service centre. The number should be on the printer or in the manual. They make an appointment for the repair with a certified engineer.
Mar 16, 2015 | Office Equipment & Supplies
Please send me contack number of customer service of EBAY PLEASE THANKS
Call eBay the number is 1-866-540-3229 available 5.00 AM-10.00 PM 7 days a week.
eBay
Dec 17, 2013 | Computers & Internet
How to reset with service menu key for videocon lcd 32'. please its urgent
What is the exact model number to your Videocon TV? Videocon uses both Toshiba and Sansui kits. Without knowing the exact kit fitted, it is difficult to inform you the correct service mode option. Anyway, check this and see whether it help you.
Jan 05, 2013 | Televison & Video
Sir i need the address of an Airtel Hyderabad Number....9908491994 My email id is vsr1987@gmail.com please its an urgent......
Sir i need the address of an Airtel Hyderabad Number....9908491994 My email id is laxmanredd597@gmail.com please its an urgent......
Feb 09, 2011 | ibibo Web Pvt Airtel iSinger
Puk and pin code urgent
call idea customer care by any other idea user and ask for your puk code by telling them the numbers on the other side of your sim card and your sim contact number............
they will tell you your puk code...........
Feb 22, 2010 | Nokia 2626 Mobile Phone
Stoves model number 059040404
try the simple things first. check continuity thro the grill element - likely the element is open circuit
Aug 22, 2008 | Ovens
Urgent assistance needed
you actually did a master reset, there is no way to recover
Mar 25, 2008 | Samsung SGH-t329 Cellular Phone
Refrigerators Logo
110 people viewed this question
Top Gaggenau Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Gaggenau Refrigerator Expert? Answer questions, earn points and help others
