Question about Freezers
I have an lec freezer serial number u661ak, the button at the top with the snowflake symbol sparked green and smoked a bitand now theres no lights working at all , is it dead or fixable do you think?? many thanks for reading
5 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: plugged a new tumble dryer into an extension lead
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Posted on Nov 09, 2009
  • 1244 Answers
SOURCE: Lec Freezer not working. Motor comes on for a few
check your evaporator fan in the back near the compressor also check to see if your lower evaporaotr coil is not clogged with dust and linT! clean it and if the fan isnt running replace it! if you find it to be lint! free and the fam is working? then shell out about $200 for a new compressor
Posted on Jan 13, 2010
bobicehouse
  • 1524 Answers
SOURCE: which is colder on my
1 is the warmest setting 6 is the coldest setting
Posted on Apr 29, 2011
  • 1156 Answers
SOURCE: my freezer is not cold. The temperature dial reads
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem....
Posted on May 07, 2011
Red light on lec freezer keeps on but not freezing
Seems like the compressor on the freezer stopped working
Jun 27, 2016 | LEC Freezers
Frigidaire triangle symbol
Good Morning Jon, this is Z. Thank you for allowing me to assist you!
I see that your post is listed under Frigidaire freezers. Please help me understand if the question you are asking is related to the "UP" and "DOWN" arrows that are designed to change the temperature setting? If you are speaking about another triangle symbol, I will need your model number please. The serial tag, which lists your model number, is normally located inside the cabinet, on the left side wall. With this information I can better address the issue at hand. Thank you!
Jul 25, 2014 | Frigidaire Freezers
Freezer Controls
Cold, Colder, B-r-r-r
Nov 23, 2013 | Freezers
Like many folks before, I have punctured my freezer while defrosting it with a knife (yes, stupid thing to do). The coolant is hissing out of the freezer right now. The question is: will the fridge still...
Once a hole allows freon to escape, it's usually best to replace the product, as moisture will enter the sealed system and contaminate everything.
Dec 10, 2017 | LEC Freezers
I have a Rank Arena BF260 freezer I got from my dad. There is a switch on the front, if it is to the left, there is no icon on it, if it's to the right it has a snowflake icon show. Dad didn't even realise...
It is the fast freeze switch. It keeps the freezer full on even if it gets down to its operating temperature. You will see the yellow or orange light come on. You do this if you want to add some new item in the upper fast freeze compartment. Make sure you turn it off after about 2 hours.
Oct 17, 2010 | Freezers
Lec freezer if i turn thr temperature up the red light starts to flash
that is because when you want a colder unit the sensor is detecting a warmer interior hence red warning light comes on.leave it at the setting you want and within 24 hours the red light will go off.
strongly recc you use a freezer temp gauge so you dont get rock hard ice cream(-18C is best)
Mar 23, 2010 | Freezers
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
Nov 09, 2009 | Freezers
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Freezers Logo
32 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
