Question about Skilsaw 5175 7 1/4" Circular Saw
Changing blade on Skilsaw 5175
Lost Manuel for Skilsaw 5175 and recall how to change blade
4 Suggested Answers
hondo73162
  • 132 Answers
SOURCE: Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Posted on Nov 09, 2009
  • 15 Answers
SOURCE: How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Posted on Jun 08, 2010
  • 49985 Answers
SOURCE: I have a Skilsaw 5175 7 1/4" Circular Saw is the bolt holding the blade forward or revers threaded
normal thread right hand thread
Posted on Nov 17, 2017
Skilsaw 3310, motor turns on and runs blade does not. Blade changed and tight on shaft
if the blade is mounted correctly and tight and the motor is running, the only other explanation for a failure is a stripped gear in the gear box
Jan 01, 2017 | Saws
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
I lost the blade wrench for my skil saw 2.3 hp and need to change the blade, what do i need to do?
you can use an opened end box wrench or a closed wrench works better - you could use a ratchet with a socket anything that will fit on there
Mar 18, 2013 | Skilsaw 2.3 Hp, 12 Amp Circular Saw
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
How do I change the blade?
use a hard board to hold blade tight
rem: unplug power cord... thats how i've had to do it
at times
May 08, 2009 | Saws
Skilsaw 5175 7 1/4" Circular Saw Logo
580 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
