Question about Whirlpool GR465LXLS Electric Kitchen Range
Dual element does not regulate it's ON or Off only
Setting the dial has no effect on the dual element shtting off. Even at Low the element stays on. This seems very dangerous and I am suprised there has not been a recall or notification on this.
  • TOM Oct 02, 2008
    Our stove had the outer ring fail on the dual burner, I ordered and replaced the entire burner from AppliancePartsPro on the internet. Strangely now the new burner (Both inner and outer) RINGS do not regulate, Full on or Off only.
    1.) When you mention "switch," I assume you are referring to the Users Burner Control Dial?
    2.) If the Switch (Dial) is bad, could the switch have forced the outer ring to go bad?
    Thanks.
    Novelist:
  • 159 Answers
If your talking about the element on the surface, I will say you have a bad switch. Its the only thing that controls the element. You can unplug the range and remove the rear cover and check the switch with a ohm meter. But like I say its the only cotrol of the element so you will want to replace it. Good luck
Posted on Jul 22, 2007
Radiant element
Most likely the switch for that burner needs replacing
Sep 29, 2017 | Kenmore Kitchen Ranges
My LRG 30357ST gas range burners flame are too low, How can I increase them?
Do they go out on low setting? If so then your regulator is faulty, Never adjust flame higher unless reg. checks out fine. Even then get a qualified tech to do that
Feb 04, 2013 | LG LRG30357ST (Dual Fuel) Stainless Steel...
With the BES860 set to Dual Wall for full automation, even on the lowest auto grind volume setting, the grind volume is too large and it spills over. This is on double setting and using the double filter...
If your using the dial gauge with a dual wall basket, you need to leave the dial in the dual wall setting. If you move it beyond the dual wall setting, you are basically adding more volume to the basket. Leave it in the dual wall setting for dual wall baskets.
Otherwise it may be faulty, it could be your grind setting, try it on 13 and see how it goes.
May 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Hob regulator wiring
OK, they are wired so that the two elements are switched in and out, to form, a single, a dual but in series, and a dual, but in parallel. like this Low, ONE, Element ONLY, The Other is out of circuit. Med, TWO elements are connected using the switch, in SERIES with each other. High, you switch TWO elements in PARALLEL. Simply meter the switch out to do that when each position is turned. Just think of it like, It's just two resistors, wired up. single, series, & parallel.
Apr 19, 2010 | Belling CookCenter 151 Dual Fuel (Electric...
Top element only stays on high
The trouble would be a failed infinite heat switch. This is the adjustable switch you are using to set the element to low, medium or high.
**Use extreme caution if you are making the repairs yourself.....Turn off circuit breaker and verify power is off with a meter. 240VAC is present at the switch. In addition, the glass top and elements are very fragile.
Apr 28, 2009 | KitchenAid Kitchen Ranges
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
I have a Inglis smooth top stove, model IME 8230. One of the front has a dial for single/dual --for quick heat up. It was working fine, til couple of days ago, it suddenly went haywire. When I turned it...
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Apr 08, 2008 | Kitchen Ranges
JBP84TOHWW GE Electric Range Large Dual Element Not Working
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
Dec 23, 2007 | GE Spectra JBP84 Electric Kitchen Range
Whirlpool GR465LXLS Electric Kitchen Range Logo
111 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
