Question about LG 50PC5D Television
Staticky picture, sound with no picture, or picture with no sound
This only happens with the HDMI connections. The picture is really staticky, and sometimes flickers before turning off.
  • jenniew2281
    jenniew2281 Jan 22, 2013
    We recently got a new PS3, and a new HDMI cable. I thought it might be the cable, but the problem still exists.
My sound gets staticky once or twice a day if I turn tv of and on it fixes it it for a little while. 32 inch toshiba vierra
If you are connected to a cable box, it may be a problem with connection. I get wierd sounds when watching my Uverse service via HDMI connection occasionally, but switching the channel up and back down usually clears the problem.
May 07, 2014 | Televison & Video
This ihome has been playing staticky noises.. It's really annoying PLEASE HELP ME.
Speaker is "blown up" because you have played the volume too loud, im not sure if its expensive or it has hq sound, but you should buy a different one, if you wanna play loud music you should get a bigger one. BTW NEVER play at max vol. or it WILL break if u use it too long.
Apr 14, 2013 | Audio Players & Recorders
TV will turn off then turn back on by itself the input shows up at the top when it comes back on. The start up sound does not play when the picture restores. Has happened when watching TV (HDMI) and play...
The first thing to do is disconnect ANYthing that is connected via HDMI and then use the component, composite or s-video inputs and see what happens. If it works ok then most likely what ever is connected to your TV via HDMI is causing the issue (it does happen). The second thing if that doesn't solve the issue is replace the lamp if its getting really dar and has never been done before. If the emmisions of the lamp are low (darker picture) the set thinks the lamp is not on and will force a restart..Please take a moment to rate my answer...Thanks
May 18, 2010 | Samsung HLP5067W Television
Powered on ps3 with hdmi lead to tv all connections are right was on ps3 yesterday then there was no picture it says unsupported video format on tv but the hdmi lead is the right socket whats happened
It sounds as if the connection has possibly reset itself to a default. Try using the normal RCA connection to start, and if you are able to get a picture, hook up the HDMI cable. You can then simply edit the Video and Sound Connections to accept your HDMI input rather than the RCA input, or you can have it select both, if you have the most recently updated software, and that way, if this ever happens again, you can still have a screen you can see.
Oct 14, 2009 | Sony Playstation 3 Black Console
Our receiver is connected to our cable box via an HDMI cable. Picture and audio show up fine, then goes out for a minute and then comes back--this keeps happening. Every time the picture/sound disappear,...
Connect the TV directly to cable box to make sure the TV and cable box are ok. If you have picture then the receiver is no good. Some Denons have problem with HDMI board (digital unit).
Oct 06, 2009 | Denon AVR-2308CI
No picture or sound with hdmi
You Need To Setup HDMI On UR PS3.
Happened 2 Me Once.
To Fix:-
Plug Into AV Multi.
Go To Settings
Go To Display Settings
Go To Video Output Settings
Select HDMI And Follow The Instructions
Apr 04, 2009 | Sony PlayStation® 3 (60 GB) Console
HDMI cable installed, have picture but no sound?
hdmi is pic only, you need to connect the sound cables too.
Dec 02, 2008 | LG 42LC2D 42 in. LCD HDTV
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
Feb 06, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
HDTV picture staticky, cuts out
I suggest contacting Sharp directly. I just did and received absolutely nothing from them. But if others such as myself who have the exact same problem as you ( I own a LC32D40U just over 2 yrs old) contact then maybe something can get done.
I will certainly NEVER recommend a Sharp product to anyone and will as of this moment respond to every message out there letting everyone know exactly how bad Sharp's product are. I would recommend the Sony XBR series to anyone looking for an LCD television.
Dec 03, 2007 | Televison & Video
Televison & Video Logo
18 people viewed this question
Computer Repairing
Computer Repairing
