Question about Garden
Leyland flywheel how to remove the flywheel on a leyland 270 tractor
    Genius:
  • 1,669 Answers
Try these helpful people:
http://www.thenuffieldandleylandtractorclub.co.uk/wp/for-sale/
http://www.thenuffieldandleylandtractorclub.co.uk/wp/specifications/
Posted on Jan 22, 2013
How do you set a magnita on a mower
The easiest way is to loosen the coils two bolts, slide it back and place a business card (feeler gauge takes to much time), in between the coil and the flywheel. Turn the flywheel until the magnets pull the coil in against the flywheel. Tighten the flywheel nuts and remove your business card.
Jul 13, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Remove fly wheel
Need model and type of engine, but usually you just remove the cover, then remove the nut securing the flywheel. Then you can use a flywheel puller or apply a little upward pressure on the flywheel with a small pry bar and gently tap the opposite top corner of the flywheel and it should pop loose. Don't hit the flywheel too hard.
Jul 08, 2014 | Craftsman Rear Mount Tiller
Yardworks 270-1241 battery full charge, sound like fan runs no motor, blade goes around, help
sounds like your starter pawl is stripped. remove your starter and inspect the pawl (gear). also check your flywheel teeth for chipping. this is usually a replacement part. If your flywheel is good just change the pawl on the starter itself
Jun 29, 2014 | Yard Machines Garden
How to replace flywheel
Most flywheels are on a tapered shaft if no puller is available loosely install the nut as not to damage the shaft and put upward pressure on the flywheel and tap the shaft end. The flywheel should come off
May 05, 2014 | Craftsman Kohler Courage 26 hp 54" Garden...
MTD Lawn Tractor: Flywheel hard to turn in one spot.
sounds like rust build up on the magnet flywheel remove the cover from the top of the engine and clean it
Aug 09, 2012 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
How to set the timming on a kolher 16hp motor
REMOVE FLYWHEEL COVER, REMOVE NUT HOLDING FLYWHEEL, USE PULLER REMOVE FLYWHEEL. REPLACE FLYWHEEL KEY. AND GO BACKWARD INSTALLING REMOVED PARTS.
May 13, 2012 | Garden
Tractor turns over but is out of time
If your tractor has B & S engine the flywheel key is sheared. You need remove shroud(cover nover flywheel) then remove the nut holding the flywheel on. Pull up flywheel, your see the key. That is the way engine is timed,
Jan 26, 2012 | Garden
Trouble with flywheel removal.
Yes, it's called a flywheel puller. Assuming it's a Briggs engine, it would be available from any shop that's a Briggs and Stratton dealer. If you want the part #, let me know and I'll get it for you. I'm not in my shop now.
Jun 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
