Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SanDisk Cruzer Micro 2.0GB not allowing me to erase files
One of the folders saved on the flash drive will not let me erase the files therein. When I erase something from that folder, "domain.dj8" pops up as if it is a file in the folder.
This folder is named: "Main Identity", and it is the only folder that is giving me a problem. The other ones let me erase with no problem.
Additionally, sometimes when I try to eject the drive, it tells me that it cannot be ejected because it is in use even though it appears not to be in use. Please let me know how to fix these problems. Thanks.
  • Anonymous Feb 10, 2009
    Ребята помогите попал вирусяка на флешку cruzer micro 2GB. Не могу с ней теперь ничего сделать ((ЗАБЛОКИРОВАЛАСЬ СОВСЕМ)) , формату не потдаётся :(  ((( Autorun.inf + Ghost.gif ))) (( мой почтовый ящик Scorpio999@i.ua )) Зарание благодарен !!!
    Scholar:
  • 180 Answers
Your drive has become write protected for this file and folders.
run computer in safe mode , chances of recovery good in safe mode.
anaesarora online
Posted on Feb 08, 2009
How Do I store Data on this?
You need you plug this USB flash drive to your computer. Computer will recognize this new flash drive and give it a drive letter, such as E, F, etc...If you can save file, folder, or copy files and folders from your C drive to this new flash drive and take it everywhere you go.
Apr 09, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
What do micro cruzer sandiscs do
your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the files or folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected files or folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do i save something to my 4GB cruzer HARD DRIVE
Assuming you have the drive hooked up to your PC, you should be able to open the drive using My Computer. You can simply open the folder and drag and drop any files you wish to save onto your SanDisk drive.
Dec 12, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can't create new folder on memory stick
Sometimes these things get confused. try moving everything to a folder on your machine then, use the SanDisk tool to format the flash drive and move everything back.
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Instructions on how to upload a powerpint
Hi...
What did you mean, if you want to save power point in you Sandisk, it is not upload it is only save. you can save this true copying files form your computer, then paste it to your sandisk folder.
Regards
PCmania
Jul 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a SanDisk Cruzer USB 8GB that is only allowing me 1.33 GB of space - says 6.594 GB used and there's nothing on here - how do I gain that storage space back? tx
There might be a hidden file(s) on the drive that are taking up that space. Open the drive in My Computer, click Tools > Folder Options... On the View tab, click Show hidden files and folders. Then check the drive to see if any hidden files or folders are present.
You can also try formatting the drive. Right click the drive in My Computer and click Format...
Mar 23, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer storage
Check the format. Make sure it's compatable with the operating system. Also check the size of your documents folder. If they are compatable, maybe there is something wrong with the flash drive.
Aug 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Making new folder and copy folder from harddrive to flash
On most flash drives there are locks that are called write protect locks. Its a switch on the drive itself that prevets you from saving on it.
Jul 27, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
139 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
