Sunbeam portable heater won't turn on
My Sunbeam portable heaters won't turn on. I have 3 & they have a test/reset on the plug. I believe the test/reset buttons are faulty. None of them work.
burzerko
  • 254 Answers
SOURCE: portable radiant convector heater -burner slightly faulty
you probably need to adjust the primary air mixture. There should be shutters on the front of the burner assy. If this does not correct the problem you may have dirty burners themselves. you could remove the burners and drag a wire brush across them to clean. but do not drills the openings unless you use a r&m bit
Posted on May 30, 2008
  • 234 Answers
SOURCE: Torpedo Reedy heater 150,000 BTU starts &
There is a flame sensor inside the burner unit. The sensor is like a photo cell that must see the light of the flame or it will tell the burner control to stop the power. You need to see if there is a soot film on the lense of the sensor and make sure the sensor is aimed straight. If the sensor is clean and aimed straight (and the problem persists) then there may be a clogged nozzle that is giving a poor flame and the sensor does not see a good flame therefore shuts down the unit. If the nozzle is at fault, then you for sure need to replace the oil filter. New nozzles are $4-8 and the size & spray angle is stamped on the nozzle. If there is still a problem, then you need to see if the pump is giving approx. 100psi pressure, then finally (the last step) would be to replace the burner control $60. Goodluck< Macgivor
Posted on Jan 16, 2010
SOURCE: Similar model compact heater will not "power up" after storage
they is no reset internal the electronic circuit is deferctive some electronics parts need no be changed. i have fixed one and modify it to be more reliable.
Posted on May 28, 2007
SOURCE: Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Posted on Dec 05, 2009
  • 31 Answers
SOURCE: York Diamond 90 issues...Turn on heater and it works for 3 mins
This could be a few different problems, It could be flame sensing issues or blower issues, But if the flame is on for around three mins then it sounds like it is over heating. Check and make sure that your filters are clean. Also check the blower wheel for excess of dirt build up in the blades. If you are getting inadequate air flow then you would get this problem. When you reset the breaker you are just reseting the faults on the main board. When the problem happened there will be a led flashing on the mainboard. If there is a little window in the furnace than you can count the amount of flashes and it will give you are trouble shooting code. You might have to jimmy the door latch if there is no window to see it. Just be careful when you jimmy the door latch because the blower will start up and you dont want your figures in there at that time. If it is not dirty then there might be some other issues. The code would help out to determine the problem.
Posted on May 22, 2010
Code ff on portable electric heater. What does code ff mean
If its a Sunbeam you need to check the electric cord an make sure it is plugged into heater an wall socket well. Really need brand an model to help more.
Jan 27, 2015 | Refrigerators
Heater won't run
It could be a variety of things, call the manufacturer, I would hope that the unit is still under warrantee.
Feb 25, 2013 | RTO Comfort Zone Electric Portable Space...
Space heater won't turn on - need reset instructions
IF YOU HAVE 2 ELEMENTS IN THE HEATER THEN ONE OF THEM IS DAMAGED THEY ARE WIRED IN SERIES SO IF YOU TURN ONE ON IT MAY WORK A LITTLE BUT TWO ON AND THE CICUIT IS NOT CLOSED & WON'T WORK AT ALL.
Dec 27, 2012 | Heating & Cooling
Sunbeam heater SQH310 keeps shutting off when it is on 2, what do I do?
If you have the same heater i do then in between the elements at the bottom there is a safety swith that bends when it heats up and breaks the connection Dont mess with it plugged in it will shock the hell out of you but if you bend it down it wont be able to lift off the circut and will stay running untill you turn it off
Oct 26, 2012 | Sunbeam Heating & Cooling
Heater core repeatedly leaks, changed 3 time in past 3 months and still no solution
You should probably pressure test the cooling system and the radiator cap to make sure it's releasing properly at the correct pressure, and to identify where any leak may exist. I would suggest that you bypass the heater core for the test first, then test once it's repaired & reconnected.
I've heard of this before due to a leaking headgasket, or small crack in the head/block as well as a bad radiator cap that won't release at the correct PSI.
Mar 26, 2012 | 2006 Dodge Caravan SXT
I have have my sunbeam electric heater model number sfh090 for a month now and it just stopped working and wont turn on or anything! i tried leaving it unplugged for a while then plugging it back in but...
Have you tested the receptacle that the heater is/was plugged into, to make sure it's working and a circuit breaker hasn't been tripped?
If not, plug a lamp into the receptacle to see if it works. If it doesn't, check your home's circuit breaker panel for a tripped breaker. If you find one, make sure there's nothing still plugged into the offending receptacle and reset the breaker. Then, plug the heater in and turn it on. Does it trip the breaker again? If it does, there's some type of short in the electrical system of the heater. If it doesn't trip the breaker, but still doesn't work, return it to the place of purchase for a replacement. However, you must have your Proof of Purchase Receipt to do this.
Hope this helps solve your problem.
Feb 17, 2011 | Sunbeam Heating & Cooling
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Why does plug on small sunbeam portable heater turn black?
Nowadays nearly all materials are commercially made,when the plug turns black that means it was over heated due to loose connection,you will not know, so after of about 15 mins u have run the portable heater,and check if the plug is hot,if yes the plug and socket are not matched so by changing to a better quality you will not get this type of problem
Oct 05, 2009 | Black & Decker BDHF600T Heater
Heating & Cooling Logo
770 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
