Question about Ricoh Aficio 2022 All-In-One Laser Printer
I have a ricoh aficio 2022 and the problem is that sow error j001 jam at the c section but there is no paper stuck on the printer
    New Friend:
  • 58 Answers
First is clean the sensors especially the exit sensor, check also the door switches maybe they are not functioning well so the jam will not be reset
Posted on Apr 24, 2013
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
male_28_cam
  • 1555 Answers
SOURCE: Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
Posted on May 19, 2010
  • 903 Answers
SOURCE: Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Posted on Jun 05, 2010
  • 903 Answers
SOURCE: Paper Jam
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Ricoh Aficio 3228c misfed paper j001. paper jam
This means the machine has been turned on with a jam inside the machine someplace. If you have opened everything in the machine and found nothing then it is time to call a service technician.
Aug 03, 2017 | Ricoh Office Equipment & Supplies
Reset aficio error sc738
what is the problem ricoh j001
Sep 10, 2013 | Ricoh Aficio 250 Copier
Error code J001 shows up after a jam
ricoh mpc3500 paper jam j001 which sensor ,no have inside paper
Jul 06, 2011 | Ricoh Aficio 250 Copier
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a aficio mpc2500 with a fault J001, I cleared the paper but is there a reset button for this
no reset button>sounds like one of the feed sensors still seing the paper or possibly covered in dust and its thinks there is still paper jam. Take all the trays out look inside see if there is any paper in there. turn the copier on with no trays in the copier.Hope that helps.
Nov 13, 2010 | Ricoh Office Equipment & Supplies
Paper jam at B2
b2 is the second paper tray on the bottom of the machine. there is a chance that it is stuck on the roller above the tray so you may need a flashlight to see this.
Jul 11, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh aficio 2022 error code sc542
2. 107
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
788 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
