It's a common problem with modern machines.
Due the modern way of washing on low temperatures some dirt will stick into the machine's.
You can try to wash some old stuff several times on a high temperature and instead of using washingpowder you have to use a handfull of soda.
It will clean the inside. Worked fine overhere.
Sounds like there are multiple problems on this machine. Dirty optics can cause light images, white streaks can be caused by dirty cortron wires(becareful when cleaning the wire or all the wires 3 usually, Q-tip can help) , not enough toner in the ink hopper, dirty cleaning blade in the drum modual. A bad heat roll can cause streaks also. Background with light images and black spots can be caused by competitive toner not working very good.
Try to print something, if there is any streaks?If no the problem is in copy glass (dadf or platen glass).
If there is streaks on print also,it could be the drum unit ( pull the drum unit out and see if on drum surface is any black streaks), fixing film is worn out, and in the worst case you have problem with toner unit ( on toner unit you have current leackage ) and you need (in best case) clean the contacts on toner unit, and in more expencive case tochange the toner unit.
hmmm..let's see..sounds like you have some residue accumulating from something possibly seeping into the tub. That can be old rubber, a metal sheath, or even an leak of lubricant. Like an old car, there are parts of every mechanical device that need to be attended to.
I'd recommend you find the most seasoned person that works on older machines, to come by and assess what is 'leaking' on your clothing. Grey comes from something metallic or rubber/plastic.
Hope you can solve this one, and keep that old machine happy.
