Question about Magic Chef MCWC45A Wine Cooler
I have the MCWC45A wine cooler and it does not cool down I can hear it "running" but the inside temp is about 62...I tried turning it off and unplugging it then restarting it and ajdusting the temp.
  • 45 Answers
Clean the filter in the back of the unit, my did this too.
Posted on Nov 25, 2013
  • 27 Answers
SOURCE: The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Posted on Aug 07, 2010
  • 27 Answers
SOURCE: Magic chef wine cooler (30 bottles) is not cooling any more
if its clicking every few minutes its the ptc relay.located to the left of the compressor behind shield with 1 screw.go to repairclinic.com...part# 1206838
rickead1
  • 1998 Answers
SOURCE: My 8 months magic chef
Warranty: all models carry 1 year warranty on parts and labor and 5 years on the compressor.
if your unit is under the warranty I would not suggest you try to fix this yourself and instead call the manufacturer and seeing how you have had it for only 8 months and if you did take the unit apart then it would void your warranty I think it would just be better for you to call the manufacturer you can also see the pros and cons of the unit on this site as well http://www.winecoolerexpert.com/magic-chef-wine-coolers.html if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future. Thanks Rick
p.s if you bought this unit at home depot return it there Thanks again
Posted on Apr 15, 2011
  • 47 Answers
SOURCE: My 8 month old magic chef wine cooler model
If it is 8 months old it probably is under warranty call magic chef they will usually send someone out. Have your purchase stub ready or they can go by the manufacture date but that might be over a year.
  • 83 Answers
SOURCE: Magic chef wine cooler model
Hi
The temperature control is normally in the inside top of the unit, sometimes at the back, sometimes at the front.
If you are competent with electrics its a fairly easy repair, only 2 wires and the ground. Do not confuse the interior light wires with the thermostat.
Switch off and unplug before starting work
Undo the screw holding the internal light, remove the cover
Knob generally pulls off or may have a small screw under the knob cap, then find how the casing is fixed, remove the casing the thermostat is fixed either with 2 screws or 1 center knut, be careful when removing the capilliary (looks like a thick silver wire) don't damage it you really will not like the smell.
Replace exactly as removed, takes lots of care and patience, use your cellphone to take images for reference if your not certain
Regards
Gordon
Posted on Apr 22, 2011
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
My beverage cooler MCBC58DST wont stay cool after it reaches target temp.
Throw it out and get another model from another company. Their units are junk!
They last a year, at best. Them and Magic Chef are one and the same...so you may have to bite the bullet and get a real unit.
Good luck. I speak from experience...I've had four now. Complete junk!!
Nov 23, 2014 | Vissani 5.8 cu. ft. Wine and Beverage...
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Magic chef wine cooler not gettng cold
at sears .com the schematic lists a "protector" part 265RFBYY
is this the overload?
also somewhere else I saw the temp stat was a problem, how would I rule this out? (Its expensive)
thanks
Jun 23, 2014 | Magic Chef MCWC45A Wine Cooler
MCWC52B wine cooler stopped cooling, compressor hot
Turn it off and place a small electric fan by compressor to cool it down.
When you turn it back on, see if you hear a clicking noise. This would indicate starting components need checking.
Nov 08, 2010 | Magic Chef MCWC45A Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Magic Chef MCWC45A Wine Cooler Logo
195 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
