Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler ch20s will crank but won't run
I checked the fuel filter it cranks only when fully choked then starts to rev up an then dies
barterjoe
  • 344 Answers
SOURCE: kohler ch20s - The engine back fires through the
Yes it could be timing except for the fact that the dipstick is blowing out. I would look at one of two things. 1. the head gasket is blown internally allowing for compression to bypass into the oil sump. or 2. the rings are worn out or on wrong allowing the compression to leak into the oil sump
If you take it to a good dealer like www.arcolawn.com they can perform a leakdown test and tell you very quickly what the problem is.
It might be worth purchasing a couple head gaskets and check. good luck
Joe
Posted on Feb 15, 2011
  • 408 Answers
SOURCE: kohler 12.5 motor starts then the longer it runs
Sounds to me like it is time for a carb kit and tune-up.
Posted on May 04, 2009
  • 168 Answers
SOURCE: engine revs up and down, improves when choking half way
Sounds like to me that your governor may need to be adjusted. Too much detail to explain here as to how to do it.
A dealers technician can fix that in 5 minutes if he knows what he's doing.
Posted on Oct 28, 2009
lindsay836
  • 677 Answers
SOURCE: Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Posted on Feb 04, 2010
  • 905 Answers
SOURCE: Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
Posted on Jun 12, 2010
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Won't rev.
Check and make sure you don't have a crack in your fuel hose. After time, the rubber fuel hose gets hard and can develop hairline cracks allowing air to mix in with the fuel going to carburetor. That usually causes a very lean condition and the engine does not want to run when the choke is off. I would recommend replacing all fuel hoses and fuel filter. Home D has a nice universal replacement kit for a good price. If your blower also has a primer bulb, replace that as well.
Oct 26, 2012 | Garden
2005 silverado cranks but won't start
I had the same problem . on my 2002 silverado it turned to be the fuel pump failed because the fuel filter was clogged. I did the work myself could saved myself 219.00 and labor if I replaced a 7.00 $ Filter .
Apr 25, 2012 | Cars & Trucks
Engine surges won't run with out choke and then it stalls
If the engine surges and won't run without choke it is starving for fuel. Best place to start is the fuel filter. After the fuel filter, pull the fuel line off of the carburetor and place a container under the fuel line to catch the fuel. Crank the engine over and watch for the amount of fuel being pumped through the line. There should be a good stream of fuel with each pulse from the pump. Chances are the pump diaphragm is getting weak and it cannot keep enough fuel in the carb to run proper. Check those items and let me know if it helps, Daniel.
Sep 29, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2001 kx65 misses very bad when trying to rev up. problem started at the end of last year. Cleaned carb (whistle clean) checked air filter, spark plug and exhaust. Sometimes it will rev up but not all the...
I would check the jetting by the color of the plug. If it's black, go smaller main. If it's white, go larger on the main. If jetting won't cure it, it probably has a crank seal out. My kid used to race these, and he blew out a crank seal trying to start it with the wash plug in the exhaust. Did the same thing as you're describing. Good luck!
Jun 12, 2011 | 2007 kawasaki KX65
Will crank but won't run
You have to get into the carb. and adjust the needle valve its either sticking or not adjusted correctly.Good luck
Mar 23, 2009 | Craftsman Garden
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
165 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
