Question about Brother MFC-8440 All-In-One Laser Printer
Black Streaks Everything I do (fax, print, copy) results in a paper with a solid black streak down the middle. The copier has been saying replace drum soon for one year, so I have learned to ignore that, but could that be the actual problem now? The streaks only started 3 days ago. It also now says toner low, but that started yesterday, two days after the streaks, and it has never done this before when low on toner. If the cartridges weren't so darned expensive, I would run right out and get one.. But the machine is about 5 years old and might be dying, so I'd hate to spend 100.00 to find out it won't fix the problem. Any help would be greatly appreciated.
  • 215 Answers
Pull drum unit out and clean corona wire by sliding blue plastic tab from side to side, making sure you put the tab back on the side that it was. if that doesn't take care of problem, then i would say you need a new drum unit.
Posted on Jan 29, 2009
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Printing black
is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
Hope that helps!
Jan 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Black streaks on copies Canon PC11
Ok. You will likely need a new toner drum or cartrige. (usually you need the drum)
May 24, 2009 | Black Box (PC110C) Print Server
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Black streaks on paper when printing message
That green bar is the drum unit. Black streaks are indication of bad drum. Replace drum unit. Don't wait too long or it will ruin the fusing section as well from excess toner build-up. Big bucks!
Please do not forget to rate your replys please.
Nov 21, 2007 | Sharp FO 3500 Plain Paper Laser Fax
Brother MFC-8440 All-In-One Laser Printer Logo
508 people viewed this question
James Cagle
James Cagle
Jim Keysor
