Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony kdf-60wf655 Went to turn tv on and power light came on to green. Fan came on. Sound came on for 2 seconds. No picture came on but tv turned off itself with red light blinking 5 times and then repeats blinking and nothing else happens. Tv is just over two years old and out of warranty!
  • patricia poole Jul 22, 2007
    Can I ohm out this bulb? If so, what would be the proper ohm range? Also, how many volts should I have coming to the molex fitting for the lamp? thanks...
    Problem Solver:
  • 5 Answers
You might try replacing the bulb before you go digging into the guts of your unit. It will cost you a couple hundred for the bulb but it's much easier to replace...
Posted on Aug 09, 2007
    President:
  • 3,130 Answers
There is a lamp driver error in your TV set. Most likely the ballast circuit for the bulb. Depending on who you take the set to, you will pay anywhere from 300 to 500 bucks to have this set repaired. This is why i recommend an extended warranty on all of these types of TV sets. This repair will involve replacing a board, and it could be one out of three of the differant boards that control the lamp. good Luck.
Posted on Jul 22, 2007
  • Larry  Dillon
    Larry Dillon Jul 23, 2007
    No, you will need to get the service manual, and trace out the circuit, and find the ballast . You do not check the voltage to the bulb, but to the Ballast circuit. If the input voltage is bad, find out why, if the input circuit is good, you will need to change the board with the ballast on it. Again you will need to invest in a service manual and know how to use it. If you cannot read a schematic diagram, you will need to take this set into a repair shop.
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
No picture - green light flicking on and off
Bulb light indicator flashes?Projection bulb use alot,an awile like about 1 or 2.The projection bulb must change it at end of it life cycles.
Apr 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Feb 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Standby/power button blinks with no picture or sound
id take it and have it repaired. people on here can tell you what they think it is but no one knows for sure what is causing the problem. a repair shop can guarantee the repair.
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
212 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
