Question about Dodge 2005 Grand Caravan SXT
2005 Dodge grand Caravan door chimes continue with key out
  • 548 Answers
SOURCE: dodge caravan sliding doors
First, keep in mind that as you begin to remove these doors you run the risk of causing serious scratches to the paint and glass, so put some masking tape and/or plastic sheeting around both sides of the door (rear quarter panel and rear glass, front door and front door glass)
I would get a Haynes repair guide since that's what I have to work from and it will tell you step by step with pictures, what to do. It's not hard, but you need to get all of the attach points unhooked to be successful. Suggest you have a helper working with you to keep the door steady.
Posted on Jan 25, 2009
SOURCE: 2005 dodge grand caravan sliding door problems
could be a partially broken wire in the wiring harness that runs in the door track. the wires are inside what looks like a plastic chain that allows it to move with the door and have seen them partially break not allowing power to flow the whole time
Posted on Feb 19, 2009
SOURCE: 2001 dodge grand caravan power sliding doors not operating
You may have already checked this but there is a switch located close to the overhead button that will disengage the door buttons for child safety, is that turned off?
Posted on Jun 05, 2009
  • 14036 Answers
SOURCE: 2005 dodge grand caravan getting code p0406
3.3 engines has the egr valve with transducer.you have to replace the whole unit. code p0406 what its trying to tell you your egr valve circuit is short to ground.it has failed .
Posted on Jul 04, 2009
  • 262 Answers
SOURCE: 2005 Dodge Grand Caravan. Code check
Cycle the key on, off, on, off. on. Then count the flashes 12 is normal 55 is end of sequence
Posted on Feb 06, 2010
Both my keys FOBs on my 2000 Dodge Grand Caravan don't work, changed the batteries, still did not work. Bought 2 new ones and the dealer could not program them.
Programming a Replacement Keyless Entry Remote ' Filear ...
filear.com/?p=131
Oct 17, 2012 - If the transmitters don't work, or if you'd rather not match the transmitters yourself, .... Tried these instructions last night on my 2005 Grand Prix.
Key FOB Not Working - The Chrysler Minivan Fan Club Forums
forum.chryslerminivan.net/showthread.../11859-Key-FOB-Not-Working
Mar 15, 2009 - 10 posts - ‎3 authors
Hi Everyone, One of my Key FOB's stopped working. Is there a way of ... Well, to be honest, you don't know where that FOB has been? LOL ... 2009 Dodge Grand CaravanSXT (3.8L), Light Sandstone Metallic, 125K miles 2005 Volvo .... By jimmy154 in forum 3rd Generation Chrysler Minivans: 1996-2000.
Key May Not Start Car or Release From Ignition : Dodge ...
repairpal.com > Problems > Dodge > Grand Caravan
Dodge Grand Caravan Key May Not Start Car or Release From Ignition. ... If the newkey doesn't work, replacing the lock cylinder including tumblers ... I am able to turn off the van, but the key is stuck in the ACC position, draining my battery. ... In reading other comments, I see it may be the FOB so I'll carry both with me and ...
2009 Dodge Grand Caravan car lock doors not working
Jan 24, 2016 | 2000 Dodge Grand Caravan
1997 dodge caravan, full battery, turn key and it clicks, door chime buzzes, wont start. what should i look at?
If it clicks it could be a bad solenoid in the starter Also check for dirty or loose battery cables on both ends . they will do that as well.
You could try and tap the starter lightly with a hammer. while turning the key because it could be stuck but that's not likely. but has happened before.
Mar 17, 2015 | 1997 Dodge Grand Caravan
Corrosion at the battery cables first. After that, remove the alarm system. Fix the wires as you go.
When I open the door on my 2005 Caravan, without the key in the ignition, the chime goes on and the open door indicator is lit. Also noticed that the mileage indicator is lit. This just happened. Normally...
It is normal operation for the odometer to light up with the driver's door being opened. It is not normal for the chime to go off. The "Key-In Switch" in your steering column is malfunctioning. The body control computer "Thinks" the key is in the ignition when it is not. It usually requires a new key tumbler assembly to fix this.
Dec 26, 2010 | 2005 Dodge Caravan
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
2005 Dodge Grand Caravan; the fob does not work for open/close, unlock/lock; inside buttons will not lock/unlock; HOWEVER, inside backseat buttons will open/close doors. Headlights, radio/cd work,...
Owen, Try this Get in close doors, don't lock them. Put key in, cycle the key on & off 4 times. Ending in the off position. After the 4th time & within 10 seconds, press the lock switch on the drivers door. If you here a chime, they are reprogramed
Jan 23, 2010 | 2005 Dodge Grand Caravan
My father in law has a 2005 dodge caravan and the door locks don't work. he has tried the fuse and diconnected the battery and it still won't work. Help!
Get in van. Close doors. Cycle ignition 4 times with key. Do not start. Within 10 seconds of the 4th cycle, press the lock switch on driver door panel. If you here a chime locks are reprogramed.
Dec 23, 2009 | 2005 Dodge Caravan
01 dodge grand caravan driver side door wont unlock, something to do with gas cas door. checked gasdoor still wont un lock....HELP!!!!!!!!!!! think it may be a relay or some type of elec problem...
Ok get in car. close all doors. Put key in ignition cycle key four times on & off. DO NOT START. Within 10 seconds of the final cycle, press the drivers door lock switch to the lock position. If you here a single chime you have reprogrammed the power door locks. This can be done of throught the EVIC system if the van has the system. If problem does not go away lock motor is bad
Nov 10, 2009 | 2005 Dodge Caravan
1996 dodge grand caravan
my manual says, 1 close doors, 2 place key in ignition & turn key between off and on position for a total of 4 times ending in the off position (do not start engine), 3 press driver side door lock button to lock doors, 4 you will hear chime when programming is completed
Jan 10, 2009 | 1996 Dodge Caravan
Dodge 2005 Grand Caravan SXT Logo
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
