Question about ACCO Brands Rexel 3150 Shredder
Where can I buy an "active safety flap" for my Rexel 3150 paper shredder.
Where to buy part a54023 safety flap
Wont automatically feed paper to shred
there is a small switch or an infra-red sensor that sees the paper. Check it in the slot of the shredder.
Paper Shredder Parts
shredderparts.com/
We sell all sizes of paper shredder gears, switches, blades, etc. to facilitate your repair. We also have shredder replacement parts for crosscut paper shredders, ...
General Shredder Parts - Shredder Repair Services
www.shredderrepair.co.uk/general-shredder-parts-227-c.asp We can supply a wide selection of parts for various makes of shredder some of the ... Paper Shredders ... Please note SRS take no responsibility for loss, damage or personal injury caused by the fitting of spare parts by non SRS personnel.
Paper Shredder Parts ' All brands inc Fellowes & Rexel ยป Document ...
https://www.documentdynamix.com.au/service/paper-shredder-parts/ Document Dynamix Australia has a strong reputation for responsive supply of paper shredder replacement spare parts and support. Whatever brand your paper ...
Jul 17, 2017 | Cars & Trucks
Do you sell the safety interlock switch for the TS4500, model no. PS-067/B?
http://shredderparts.com/tech-solutions-1.php
If you could take it apart, you could bypass the interlock. I would not do this if you have children, unless you buy a lockout box.
I would try and glue the pin with superglue.
Aug 16, 2015 | Tech Solution TS-4500 Shredder
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
Fellowes c-220c always full
there is usually a flap that leans into the paper tray and when it gets full the shreds push on this flap and activate a switch...
look for the flap and see if it bent or came off it's hinges.
Apr 14, 2010 | Fellowes DM15C Shredder
Paper jammed between blades
it must be a switch that percive papers. just in front of the where you giving paper.
May 29, 2009 | Office Equipment & Supplies
Shredder says service due. cannot clear display
Clearing the "Service Due" prompt:
1. Lift safety flap (plastic cover over paper entrance).
2. Depress Reverse and Stop button simultaneously 2-4 seconds.
3. LCD display reads, "Service Info 1"
4. Press Stop button once to obtain "Service Info 2"
5. Depress Forward and Reverse buttons simult. 2-4 seconds.
6. "Service Due" prompt will be cleared and service hours zero.
7. Snap safety flap down to close.
Apr 06, 2009 | ACCO Brands Office Equipment & Supplies
Bin light is staying on and we cannot shred any paper. The shredder does not appear to be jammed anymore. what can we do?
check underneath to see if the bin full flap is working.
First, uplug from power. Look underneath and see if you have a flap. If you do, then make sure it's quiet and move the flap back and forth. You should hear a microswitch click.
If you don't have a flap and the hopper is removeable, make sure hopper is installed properly.
Dec 18, 2008 | Fellowes SB-99Ci Shredder
Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Oct 24, 2008 | Office Equipment & Supplies
Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Mar 01, 2008 | Office Equipment & Supplies
ACCO Brands Rexel 3150 Shredder Logo
Top ACCO Brands Office Equipment & Supplies Experts
Tom Chichester
Are you an ACCO Brands Office Equipment and Supply Expert? Answer questions, earn points and help others
