Question about Riccar Sewing Machines
Riccar foot pedal and mains lead
Model 808E footplate model nc-7 Where can I obtain a replacement footplate and mains lead from?
SOURCE: replacement foot pedal and wiring for Euro Pro
Here's a place that carries all the pedals. Many are used by various brands, and go under different names for different machine companies. The euro-pro manual has the manufacturer's name and the model #, or you can browse the drawings of pedals to match your own. My euro-pro 9110 uses a model also used by viking and huskevarna. This place carries the cords as well.
Good luck.
http://sewingmachine221sale.bizland.com/store/page36.html
Posted on Jul 26, 2008
  • 323 Answers
SOURCE: White 1934d Superlock foot pedal/lead cord
Go to your local dealer and let him replace what you have with a generic foot control. Should take him about 15 minutes. What kind of problem do you have with the one you have? If it is a cord problem it may have to be ordered from a wholesale supplier or a white dealer may have one in stock.
sewman7
Posted on Apr 25, 2009
  • 4 Answers
SOURCE: Need to find replacment for foot pedal.
Try calling EURO- PRO X Shark at # 1-800-361-4639. They are VERY helpful!
Hope this helps!!
Posted on Aug 21, 2009
  • 6 Answers
SOURCE: I have a Riccar Super Stretch 808E sewing machine
Maybe the belt is too tight or the thing just might be seized if it hasn't had a service (oiling.... plus) in a while
Posted on Aug 26, 2009
  • 980 Answers
SOURCE: need a mains lead
You need to either take a drawing of the plug on your machine and go to your l;ocal dealer if you have one or take the details off the motor
Posted on Apr 09, 2010
How do you replace bobbin
Usually, slide back the footplate, release the catch on the bobbin holder and lift it out.
the manual is available here at a cost
http://www.sewingpartsonline.com/instruction-manual-singer-5400.aspx
This one says it is available free
http://issuu.com/service-repair/docs/singer_5400_series_service_manual.pdf
Sep 23, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
I am trying to source a set of motor brushes for a YDK YM-170C-A Motor, as found in the Riccar 808E Sewing m/c. Also a memory card No.RB-220-02 for the same machine.
Hi
Our YM-170C-A motor is similarly not working. Can you tell us if you fiound a way of sorting the problem please or likely supplier of replacement motor perhaps? A direct email would be great please.
Many thanks
John Norfolk
jhnorfolk@googlemail.com
Jul 07, 2010 | Riccar Sewing Machines
808 E that I need a diagram for.I think it the hook gear that broke but before i order one I want to make sure thats what it's called
A common problem with the Riccar 808e is a broken hook gear.
The part number is 53741 and usually runs about $15.
Putting it in is easy but then you must re-time the hook. Let me know if you need help with it. I'm not sure where you can get a diagram or a manual...
Aug 21, 2009 | Sewing Machines
STITCHES BACKWARDS SINCE I OILED IT YESTERDAY!!
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this.
Please don't use all capitals when typing, it is the online version of shouting, and is difficult to read.
Aug 01, 2009 | Sewing Machines
Threading the bobbin
Threading the bobbin - winding thread onto the bobbin.
Position the new empty bobbin onto the vertical bobbin rod next to the end wheel. Click the rod to the right to engage drive. Hold the outer end wheel with left hand, and rotate the inner wheel anticlockwise by about a 1/2 turn (it stops) this removes drive from the foot and needle mechanism.
From a spool of thread on the top, thread to a loop/post on the left on the top. Then back to the bobbin you want to wind. Thread through a hole from the inside-out. Hold the thread vertically above the bobbin while you depress the footswitch to start winding. Let go when it's turned a few times.
Move bobbin shaft left, and tighten end wheel after winding enough.
Fitting bobbin-
Move footplate towards you, insert bobbin in hole so that bobbin rotates anticlockwise when thread is pulled, then pull thread into the fine notch towards you. After this position thread away from you, and slide the footplate closed.
To start / load thread. Hold the end 3" of the thread through the needle behind the sewing foot. hand crank towards you to sew first stitch in air. This should retrieve the lower thread - which you can catch with a handy pair of scissors. Then pull both threads rearwards - ready to sew.
Jun 11, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
46 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
