Question about Hotpoint Ultima WF860 Front Load Washer
Cannot open door
F5 keeps flashing cannot open door
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
F5 means a blockage. you will need to drain it by putting the drain hose lower than the machine to syphon it out into a basin. then you can check the filter for the cause.
Posted on Jan 27, 2009
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
I have a F5 E7 error code door keeps locking
F5-E7 Code - Self clean latch will not unlock
Check this procedure to solve it:
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to
step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to
step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes
Hope this helps.
Oct 07, 2011 | KitchenAid KESC308LSS Electric Kitchen...
F5 E1 error. Oven door won't open after running cleaning cycle
1.
If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
5. If
6. If failure
Note:
Applies to all F5-E... codes.
F5 - E1
Feb 21, 2011 | Whirlpool RBS275PD Electric Single Oven
After cleaning, the oven will not work, it keeps flashing F5, whats the problem?
Hello & Welcome to FixYa
Error code F5 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | KitchenAid KESC300 Electric Kitchen Range
F5 error door locked
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 27, 2010 | Whirlpool RBD275PD Electric Double Oven
My kenmore oven will not work . it flashes an F5 code.
Hi, the f5 error code is a door lock code, which means there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Oct 19, 2010 | Ovens
Selfcleaning won't come on E1 F5 keeps flashing with a beep
Hi
Thanks for using FixYa. Error F5-E1 means that the door latch/switch has gone bad or is not operating. To resolve this issue check the door latch and replace if its not working. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 05, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven keeps coming up EO -F5-, and cannot work oven.
Here is what the fault code means:
F5 E0 14 Door switches do not agree Check door switch. Contacts should be closed when plunger is actuated. Check door switch circuit for open.
Feb 28, 2010 | Whirlpool Accubake RF362LXTT Electric...
Whirlpool accubake oven door will not open e1 f5 and e0 f5 error codes
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Feb 09, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint Ultima WF860 Front Load Washer Logo
462 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
