Question about Garden
Where is the oil plug on a huskee lawn mower with a honda motor
  • 15 Answers
SOURCE: oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Posted on Apr 23, 2009
cxbxr_3
  • 11 Answers
SOURCE: Honda Self-Propelled Lawn Mower leaking oil?
It is toast you fried the crank/connecting rod, by running it low on oil.
Its hard to say what caused the oil leak, but now it is ruined.
Posted on Aug 12, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
rwvanlue
  • 486 Answers
SOURCE: oil change in yard man lawn mower
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Posted on Dec 06, 2009
I have a huskee 21inch 140cc pushmower that won't turnover. It's like the shaft or piston isn't even connected. What do I need to do to fix it?
broken main rod will cause this pull plug and check and see if piston blows air out if dont broken rod then replace lawnmower or the engine other motor junk if it has a poped valve seat to fix it is also not worth it replace mower
Sep 27, 2014 | Garden
I have a huskee lawn mower and is not reving high enough to cut with out stalling
First check the air filter, it should be new every year (season). Drain the oil and ensure you are putting in the correct amount, (most lawn mowers hold 2/3 qt. Make sure the gas is fresh and the spark plug replaced. Lastly with the spark plug removed squeeze the handle/lever as you would to start/stop the engine. Have a helper turn the engine over by the blade, if the engine turns over freely good, if there is a drag or it's stiff it could be the engine brake around the flywheel is mal-adjusted
Jul 15, 2014 | Garden
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Need to change the motor oil in my lawn mower, **** Super Z with Honda 24 hp motor. How many quarts of oil does this require?
You should have a GXV670 Honda on that beast. If so, then 2.5 quarts with a filter change.Good luck.
Jun 26, 2009 | Garden
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Jun 06, 2009 | Garden
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Oil drain plug
Apr 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
