Question about Hoover Washing Machines
A knocking sound when it spins
Optima
    Sergeant:
    Champion:
  • 249 Answers
What is the drum doing whan you start the washer with the drum
Posted on Jan 22, 2013
04 kia optima 2.7 V6 changed out altenator and Serpentine belt When I start the car it reeves engine 2000 rpm then climbes to 4000 rpm than back down to 2000rpm repeats over and over Serpentine belt is...
Sound like you either had to disconnect a wire to get out of the way when you removed the altinator and didn't reconnect or you knocked one off go back and check your work.
Aug 29, 2014 | 2004 Kia Optima
2005 kia optima lx v6 engine started knocking on right side of motor heater wouldnt work earlier that morning
check for low coolant, look for coolant bubbling up in over flow bottle
if there is call a mechcanic
Mar 27, 2014 | 2005 Kia Optima
Kia optima engine ticking
sounds like lower end bearing damage (connecting rod) when oil level drops at interstate speed a connecting rod bearing will seize very quickly thus causing the bearing to spin in the rod and enlarge clearance . that is the knocking sound you here .
Sep 03, 2012 | Kia Optima Cars & Trucks
Kia 2.4 optima 07 engine makes knocking noise when I press fuel pad to move..I can't press fuel pad strongly the knocking noise increases more and may broken the rings
Sound like you have spun a bearing do to a blown head gasket. Does the oil on the dipstick look almost like a chocolate milkshake in color? If so your coolant has reached the oil pan and that can definitely cause the engine to spin a bearing causing a loud knocking sound.
Apr 03, 2012 | 2007 Kia Optima
My car won't stay cranked after Iv'e changed my spark plugs. Did i knock anything loose?
REPLACE SPARK PLUG CABLES.IF YOU REPLACE SPARK PLUGS GOOD THING TO REPLACE PLUGS CABLE ALSO.
Nov 28, 2010 | 2006 Kia Optima
2002 Kia Optima has a knocking sound until the engine heats up and then smells like an overheated engine, lots of clicking noises after you turn it off. Checked the antifreeze level, at the top, there is...
It's possible that your oil level is low or it's time for an oil filter change.
If not, it's possible that the rockers need adjustment, but I doubt it. Good luck
Sep 27, 2010 | 2001 Kia Optima
Sounds like broke timing belt but timing belt is not broke i have the v 6 dohc motor
What or how does it sound like a broken timing belt? Is the engine knocking? If the belt is not broken, it might have slipped and the timing may now be off, enough to cause the sounds you're hearing.
Sep 22, 2010 | 2002 Kia Optima
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Washing Machines Logo
21 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
