Question about Welding Tools
Need to know easiest technique for soldering stained glass.
  • 4 Answers
Looks like you might be using solder with flux already in? If so, don't. Buy liquid safety flux and paint on generously over the glass as well as copper foil (I take it there is copper foil under there somewhere??)
Solder should be "F" grade, 50% lead, 50% tin, which is soft and flows well.
Don't apply too much on outside edges to start, but build up a raised bead on any internal joints. Turn over, flux again and repeat soldering on second side. Then hold work upright using a cloth, to protect your hand from possible drips of hot solder and apply more to the outside edge all round, bit by bit. This should be fairly thick for strength and is not easy, but possible if you hold your work with the edge you're trying to solder, absolutely level, otherwise the solder will just run downhill. It's a bit like the mercury puzzles you used to get.
Hope this helps
Posted on Mar 13, 2013
    Genius:
  • 1,669 Answers
Try some of these:
http://www.delphiglass.com/page/knowledgeBaseView?KBItemID=16
http://warnerstainedglass.com/techtips/solder.aspx
http://www.elvesofester.com/soldering.html
Posted on Jan 22, 2013
2 Suggested Answers
sivaranjini
  • 241 Answers
SOURCE: iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Posted on Nov 25, 2009
    How do I clean beko oven door inside panel?
    Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
    Dec 28, 2013 | Ovens
    I am having problems learning to solder stained glass.
    I am no expert on this process at all but I know enough to see that you are doing this wrong. First off there is a lead channel that you use to fit the glass in and then you just solder the joints together where they meet. The second is you wil need a soldering torch to heat this up fast enough for a clean solder. I am very well versed in soldering on the electronics leve and there is one basic....the right heat is essential.
    Jan 22, 2013 | Welding Tools
    How do I get the white heat stain off of my tempered glass, air tight gas furnace?
    You'll need to remove the glass from the fireplace, but not before turning off the pilot light. Then mix a 50/50 solution of White Vinegar & Water. Using a sponge soaked in the solution and partially wrung out, clean the glass on both sides using the solution & sponge. Reapply as necessary until the glass is clean. Dry thoroughly with paper towels, before reinstalling the glass.
    The heat stain is not really a heat stain. It's left over residue, from when someone used commercial glass cleaner to clean the glass. The white stain is from the ammonia in the cleaner.
    Hope this helps you and thanks for choosing FixYa.
    Sep 16, 2011 | Heating & Cooling
    I spilled liquid on the HP 5610 scanner. Now I have a stain on the left margin of my scans. The stain is a strip that extends from top to bottom. How do I remedy this?
    One way to remove all types of stains and fingerprints is Windex and a soft rag. That is one of the cheapest and easiest way to do it.
    A better approach to it is to use monster cleaner. It is a special spray to clean tv screens, laptop screens, and even windows. It comes with its own cloth that works amazingly well. I have used it for years and has worked for me every time. You can pick it up at your local Best Buy or click on the link to buy online. http://www.bestbuy.com/site/Monster+Cable+-+TV+Screen+Cleaning+Kit/5774879.p?id=1069297113224&skuId=5774879&st=screen%20cleaner&cp=1&lp=1
    May 06, 2011 | HP Officejet 5610 All-In-One InkJet...
    I have an exterior copper lantern with broken glass panels. the lantern is completley soldered from the inside out.
    Contact a glass company, but also look for a stained-glass maker.
    Stained glass is set inside a soldered frame. That person will have the tools to fix it.
    You will probably have to get a handy-man to remove the outdoor lamp so it can be taken to the glass shop.
    Oct 30, 2010 | Cooper Lighting Lighted Switch
    Something to make soft solder blend in more to gold color jewelry
    Was looking for a patina - used in stained glass - this is what others suggest...
    "I use gold leaf paint at my solder points in a stained glass piece to make it look like brass. Have repaired many pieces and used the gold leaf paint and works very well. I think the paint works better than the gold pen."
    Gold'ish color at least - hope this helps... Dan
    Dec 09, 2009 | Welding Tools
    Iron is not heating up hot enough stained glass soldering iron:
    hi friend,
    check this out
  • hope this helps u
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    Hard water stains on my car's wind screen
    Windex and newspaper should do. You sure they are water spots and not the glass? When they set out the plastic impregnated in the glass (safety glass), seperates slightly and looks like a water spot or even a bubble. It is a combination of heat & sun rays. May have to live with it or replace the glass.
    May 03, 2009 | 1995 Mercedes-Benz E-Class
    Glass Door stain
    you can clean it but its not easy u have to remove the door put it on the floor remove the screws from the side and the bottom the glass should slide out then then u remove more screw to get the other piece of glass then u clean it and put it all back togather
    Mar 16, 2009 | Kitchen Ranges
    Welding Tools Logo
    97 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
