Our Whirlpool Duet GHW9200LQ washer will not always start a cycle when you press the START button, although it does not give any error code. What's wrong?
  • 8 Answers
I also have this problem. I removed the control panel, removed the green start button, put the control back together and pushed the red button on the panel and the washer works again. I just have to replace the start button.
Posted on Feb 08, 2013
  • Charlie Lapinski Feb 08, 2013
    no that will not help you for what you need to do okay
  • Scottthefixi Jan 03, 2017
    Here is a video on how to repair the broken start button using duct tape.
    It saves you about $300.00 on a new interface control board.
    Hope this helps:https://youtu.be/N8rz8sclwAg
    Good Luck,
    Scott
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Hope this helps: https://youtu.be/N8rz8sclwAg
Good Luck,
Scott
Posted on Jan 03, 2017
    Sergeant:
    Champion:
  • 249 Answers
You might need a new User Control and Display Board part number is 8181866. the pic below is the User Control and Display Board looks like that
Our Whirlpool Duet GHW9200LQ  washer will not alwa - 1_22_2013_9_53_23_pm.jpg
Posted on Jan 22, 2013
  • 1122 Answers
SOURCE: whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Posted on Oct 18, 2008
sdmc73
  • 121 Answers
SOURCE: whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Posted on Nov 29, 2008
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 3230 Answers
SOURCE: whirlpool duet washer model: GHW9200LQ
I found this in when I looked it up.
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. - or -
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operati
Posted on Mar 28, 2009
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    F30 error code...what is this problem?
    F30 is a dispenser failure code on the Duet Sport washer.
    It means the dispenser motor will not go to the proper position.
    Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
    Post back with what you find and we will check from there.
    Thanks/Mike
    Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    I keeg getting the dreaded F11 anf DL code!
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    PLACEHOLDER FOR ART
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, then call for service.
    Take care
    Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
    I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
    I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
    May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
    We have a Whirlpool duet washer that doesn't finish washing
    its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
    Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    After pressing the pause button on my Whirlpool duet washer I got an F01 error code. From checking around online, it seems that this happens to alot of people when they use the pause button. Would this be...
    Error code F01 =EEPROM ERROR
    A communication error between the Central Control Unit (CCU)
    and the EEPROM onboard the CCU occurred.
    PUMP DRIVE ERROR
    The pump driver fails to activate.
    MAIN RELAYS ERROR
    One of the main relays is not working properly.
    A power glitch may cause this error.
    Unplug washer or disconnect power for two minutes.
    Verify CCU operation by running a Diagnostic Test or any cycle.
    Replace CCU board.
    The relay might be soldered or always open.
    Replace CCU board.
    Nov 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Whirlpool duet gas dryer PF error will not reset as per manuals
    PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Whirlpool duet washer problem
    The following link explains the "FH" error code:
    http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
    First, try to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, then proceed with the steps outlined in the link I provided for you.
    This is one of the more "involved" error codes that you may need spend some time with. Although, it may NOT be a difficult repair, it still may require some diligence to figure out the cause. I would recommend checking your washer installation for a potential siphoning problem and then check the drain pump as these are the more common causes. If you require additional assistance, please let me know. I hope this helps you.
    Jan 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Intermittant trouble with code d 11
    Answer Duet HT®
    Duet®
    duet_f_dl_actualsize.gif Duet SportTM
    This error code indicates that the door is not locking.
    Is the washer door firmly shut?
    The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
    Were you washing a large load?
    Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
    fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet washing machine will not start a cycle.
    sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
    Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    254 people viewed this question
    Top Washing Machines Experts
