Question about Archos 101 Internet Tablet
My archos 101 tablet wont charge any solutions
My battery won't charge at all could it be the charger or port
  • 22 Answers
SOURCE: Archos 101 internet tablet cant get
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
Posted on Feb 28, 2011
  • 22 Answers
SOURCE: Will ethernet USB cable work with Archos 101 as it
Archos support is correct, if it doesn't use a simple interface like a hard drive or mouse/keyboard, then it won't work on the Archos 101.
Manufacturers aren't releasing Android drivers yet for the most part, so I wouldn't expect an ethernet to USB cable to work any time soon, sorry!
djredskyy
  • 670 Answers
SOURCE: Cracked screen on recently purchased Archos 101
It should be free if you have insurance and it is under warranty
Posted on May 08, 2011
mc1bean
  • 3053 Answers
SOURCE: My archos 101 tablet is frozen and none of the
If you have access to battery, remove battery and put back in.
Posted on May 29, 2011
  • 8 Answers
SOURCE: I reformat my archos 101
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
20.3.1. To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. Recovery mode options No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration
Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased.
HOPE IT HELPS AND GOD BLESS!!!
Posted on Jun 27, 2011
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit.
Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing.
Try using a different charger that will deliver 5 Volts at 2 Amps...no less.
If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
Mar 12, 2014 | Insignia - Flex 10.1" Tablet with 16GB...
Arnova 7k g3 wont charge
You probably destroyed the port plate of the charger. You should check if it is bent or dented and if they are the price to get it fixed is $50-$150
Jan 20, 2014 | Archos Arnova 7 G3 Tablet
Battery not charging
Is it loose connection. or any problem with charger or tablet. give it to any service centres
May 24, 2013 | Samsung Tablets & eReaders
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Need a new charger, not sure whats safe or compatable...help plz
Go to eBay and search for your charger. Once you go to www.ebay.com type in Archos 101 Internet Tablet AC Adapter and hit the search button. They cost $8.76 and they are made for your tablet.
Mar 20, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
How much time shall i charge the ARCHOS 101 internet tablet when i charge for the first time.
Never haven used one, I'd see if the directions that came with it tell you anything. If not, I'd go with the fairly common practice of a 12-hour charge that many manufacturers recommend for electronics.
Sep 25, 2011 | Archos 101 Internet Tablet
My machine will not charge and is very slow
It ispossible that sometimes the battery takes a longer time to charge if the voltage of the adapter is low. So after the battery is fully discharged , you must allow the charger to be connected overnight. If the battery does not charge fully then the battery and the adaptor must be cross checked in another unit.
If under warranty you must claim for replacement.
Sep 20, 2011 | Archos 101 Internet Tablet 501590
MY ARCHOS 101 WONT TURN ON AT ALL. PLUGGED INTO WALL OR LAPTOP. NO LIGHT OR ANYTHING.
Unfortunately this seems to be a recurring problem with the 101, and I can find no solution besides returning the unit to Archos for repair/replacement. You can find information on their homepage regarding RMA process.
Jan 24, 2011 | Archos 101 Tablet PC
Archos 101 Internet Tablet Logo
1,389 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
