Question about Welding Tools
I am having problems learning to solder stained glass.
  • 3,904 Answers
I am no expert on this process at all but I know enough to see that you are doing this wrong. First off there is a lead channel that you use to fit the glass in and then you just solder the joints together where they meet. The second is you wil need a soldering torch to heat this up fast enough for a clean solder. I am very well versed in soldering on the electronics leve and there is one basic....the right heat is essential.
Posted on Jan 22, 2013
2 Suggested Answers
sivaranjini
  • 241 Answers
SOURCE: iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Posted on Nov 25, 2009
    On order 2393045491 I ordered item # 6332 I thought it was supposed to be stained glass not plastic
    You have a stained glass, plastic microwave oven? Stained glass is very expensive.
    Feb 05, 2017 | Microwave Ovens
    How do I clean beko oven door inside panel?
    Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
    Dec 28, 2013 | Ovens
    Need to know easiest technique for soldering stained glass.
    Try some of these:
    http://www.delphiglass.com/page/knowledgeBaseView?KBItemID=16
    http://warnerstainedglass.com/techtips/solder.aspx
    http://www.elvesofester.com/soldering.html
    Jan 22, 2013 | Welding Tools
    I have an exterior copper lantern with broken glass panels. the lantern is completley soldered from the inside out.
    Contact a glass company, but also look for a stained-glass maker.
    Stained glass is set inside a soldered frame. That person will have the tools to fix it.
    You will probably have to get a handy-man to remove the outdoor lamp so it can be taken to the glass shop.
    Oct 30, 2010 | Cooper Lighting Lighted Switch
    Something to make soft solder blend in more to gold color jewelry
    Was looking for a patina - used in stained glass - this is what others suggest...
    "I use gold leaf paint at my solder points in a stained glass piece to make it look like brass. Have repaired many pieces and used the gold leaf paint and works very well. I think the paint works better than the gold pen."
    Gold'ish color at least - hope this helps... Dan
    Dec 09, 2009 | Welding Tools
    Iron is not heating up hot enough stained glass soldering iron:
    hi friend,
    check this out
  • hope this helps u
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    Burnt on stains on the inside glass door of my kitchenaid oven
    DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
    Check out debrucepolish.com.
    DEBRUCE METHOD on You Tube
    Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
    Staining of kitchenaid glass top digital control unit
    Have you tried using a razor blade scraper. Also I have found Ceramabrite cooktop cleaner to be a very good product. There is also a less abrasive scouring pad available specifically for glass cooktops.
    Jan 02, 2009 | KitchenAid 30 in. KECC506R Electric...
    See through oven glass window stained
    this is common its called vapor lock look for screws holding in the glass if none are found there is a rope looking seal around it take a hook or pliers and remove it the glass will come out you can clean in between it and put it back fairly easily.
    Dec 30, 2008 | Ovens
    Welding Tools Logo
    118 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
