Question about GE WSM2780W Stacked Washer / Dryer
Why is my GE Spacemaker Dryer WSM2780 squeaking?
Should I just replace the belt or could there be another problem?
  • 4 Answers
It is probabaly the felt bearings at the rear of the machine
Posted on Jan 22, 2013
  • 52 Answers
SOURCE: GE Spacemaker washer/dryer
If you can get it apart, you should be able to fix it yourself. This is a tricky task though (I've seen customers spend hours just trying to change a belt, which you'll have to remove), so you may want to pay the money and have someone come out.
It is hard to say without hearing the noise for myself, but my best educated guess would be that the dryer drum bearing needs to be lubricated. You should lubricate it with white lithium grease, about 1.5 ounces of it.
In order to do this, you will have to take the dryer front off, remove the belt from underneath the drum and then remove the drum. You will see a bearing on the backside of the drum (looks like a post with a ball on it). You will see where that inserts on the back wall of the dryer. You should put the grease in the insertion point, then put the dryer back together again.
Posted on Mar 29, 2008
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
  • 8 Answers
SOURCE: GE spacemaker dryer won't start
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Posted on Jan 13, 2009
ginko
  • 19396 Answers
SOURCE: Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 06, 2009
tomcattech17
  • 214 Answers
SOURCE: Need to find a replacement
Go to:
http://www.partselect.com/ModelFrames.aspx?ModelID=523375&ModelNum=wsm2700dawcc&mfgModelNum=&ManufactureID=2&Selected=00112795i01&Position=1&mfg=GE&Type=&Mark=1
or
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5237336
Posted on Jun 10, 2011
I have a GE Model WSM2700 WSM2780 Spacemaker Laundry stacked washer/dryer combination which is about 8 years old. It worked perfectly until the dryer no longer would turn on. I opened up the unit and...
i had something similar, did the cleaning and double checked to make sure all the wiring was hooked up and not frayed. i then "jiggled" (technical term) the dryer door button and some sand came out. it has been working ever since.
Apr 14, 2011 | GE WSM2780DWW Unitized Spacemaker Washer...
The dryer squeaks while drying.
Hello and Welcome to FixYa
Dryer make this squeaking sound when the belt is either worn out or is bad. You can check this example video which tells you how to replace the belt:
Kevin
Dec 02, 2010 | GE DCVH515EF Electric Dryer
Wsm2780 washer not rotating and make a squeeze noise
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
rtywe
Jun 13, 2010 | GE WSM2780W Stacked Washer / Dryer
The belt in my dryer is squeeking. What type of
It's probably the front tub guides that are worn out causing the squeak. It's a felt lined circular shaped guide that holds the front of the tub. The rear of the tub is held by a ball and socket bearing. Access to the guides is behind the front panel of the dryer. Remove the screws across the top
May 10, 2010 | GE Spacemaker Washer and Dryer Electric...
GE Dryer DDE7900 squeaking.
it could be the drum belt that has glazed from age or the front drum glides/rollers or even a rear bearing on the drum
Nov 14, 2009 | Televison & Video
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Ge spacemaker washer and dry stackable.
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Mar 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WSM2780W Stacked Washer / Dryer Logo
208 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
