Question about Cycling
Light indicator on 97 Toyota Camry dashboard
    Genius:
  • 1,669 Answers
I see 2 light indicators: one for the seatbelt not fastened and another can't be seen as an indication of what it is. Please be more specific!
Posted on Jan 22, 2013
I am noticing a flashing light on my dashboard. The item flashing is a car with lines coming from behind the car. it is beside d seat belt icon. What does it mean, and how can I fix it?
the symbol with a car and 2 curved lines behind means:
"Slip control" or "Stability control" (also known as ESC, ESP, ASR or DTC) warning.
Toyota Trac Inop Light Toyota's traction control helps you maintain traction on wet, icey, loose or uneven surfaces. There are complex wheel speed sensors that will trigger the traction control safety feature as needed. If you see the trac inop light illuminate, this feature might be disabled. A Toyota service rep can access the trouble code and identify what is needed to fix any potential issues. - See more at: http://jeffwylerclarksvilletoyota.com/section/secondary/toyota-dashboard-indicators#.dpuf
Toyota Dashboard Indicators
Jan 15, 2011 | 2003 Toyota Camry Solara
Unknown light indicator in the dashboard
it is a rear bulb failure light,have you checked the reversing light bulbs...?
Jun 18, 2010 | 1995 Toyota Camry
Does my 1997 toyota camry ce 4 cylnder have abs im changing my front axel
ABS was optional on the 97 Camry CE - some have it, some don't. If your car is equipped with ABS, you should have an ABS indicator light on the dashboard, that goes on when you first turn the key in the ignition. But if you are not able to determine whether your car has ABS, it's not a problem. The axles compatible with ABS will also work if your Camry does not have ABS. They cost about the same as axles without ABS. So if you are not sure, just buy the axles for ABS.
Mar 09, 2010 | 1997 Toyota Camry
Car with skid marks lighting up on dashboard what does this mean?
this is a traction control fault indicator light. this is most commonly caused by a faulty wheel speed sensor. you'll want to bring the car into the shop to be hooked up to a computer for a proper diagnosis.
Feb 17, 2010 | 1999 Toyota Camry Solara
A light indicating a car on my dashboard is on. toyota avalon 97
Look close at the car on the dash, is one of the doors open? How about the trunk? Fuel filler? Gotta be something like that.
Feb 12, 2010 | 1997 Toyota Avalon
How do I get access to the dashboard to install a new ignition key on a 97 toyota camry
Firstly open the door by lifting the door handle,pull outwards,place new ignition key in slot of switch.Hopefully you had the key cut first to suit.Then turn clockwise(same direction as a clock)
Jan 30, 2010 | 2000 Toyota Camry
97 toyota camry brake light is on in my dashboard
Check the brake fluid level and top off to full mark if it still stays on then you have a brake system failure in the hydrolic system front or rear brakes are not working and the light is telling you that.
Jan 05, 2010 | 1997 Toyota Camry
97 CAMRY TAIL LIGHTS NOT WORKING
Its right above the fuse box. You need to remove the plastic kick panel to see them
May 01, 2009 | 1997 Toyota Camry
Toyota camry 2004 dashboard lights switch
First turn on the parking switch & then turn the illumination light knod clockwise located in the dashboard.
Feb 27, 2009 | 2006 Toyota Camry
2001 toyota camry dashboard light
that is indicating one or more of your rear lites is out. ck carefully including brake lites.
Dec 04, 2008 | 2001 Toyota Camry
Cycling Logo
942 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
