Question about HP Photosmart 2575 All-In-One InkJet Printer
Photosmart 2575 says paper jam but no paper jam is present. The paper appears to feed too far in on initial carry. Press the OK button and the paper exits with no problem.
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
Corysf62
  • 188 Answers
SOURCE: paper jam without any paper deskjet F370 all in one
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Posted on Nov 06, 2008
SOURCE: paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Posted on Mar 24, 2009
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
micromaster
  • 3614 Answers
SOURCE: Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps.
Posted on Aug 08, 2009
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Message 0xc05d1281 message is continually displayed. Have tried all the suggestions on website by other users. Possibly small piece of paper jammed as problem started once paper jammed. Can you tell me how...
Hi there 0xc05d1281 Problems
The "Ink System Failure" error is causes by air in the ink feed tubes.
I hope this helps, If so please rate our solution.
Please perform the following steps in order:
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say "support" R0631M"
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
You should be back up and running.
Click LINK= http://www.4all2sell.com/pdf/http://www.4all2sell.com/pdf/HP-photosmart-3300-3310-3310xi-3313-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
Feb 16, 2010 | HP Photosmart 3310 Printer
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Paper will not feed
It is a problem with printer paper sensor pls clean the printer paper sensor. if problem does not solve then you can checked it from service center.
Oct 20, 2009 | HP Photosmart 2575 All-In-One InkJet...
Paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Jan 03, 2009 | Office Equipment & Supplies
Paper jamming
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | HP Photosmart 2575 All-In-One InkJet...
2575 paper jam
This worked for me. If "Paper Jam" error message continues to appear after jam has been cleared, turn off power to printer. Navigate to Control Panel - Printers, right click on HP Photosmart 2570 series icon, click on Delete on drop down menu. This deletes printer from your system. Turn on power to printer. Printer will re-install (may need original installation disc, may not). "Paper Jam" error message should no longer appear.
Mar 27, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP 2575 Paper Jam
CLICK ON O.K. PRINTER WILL CLEAR ITSELF, BECAUSE THERE IS NOTHING IN JAM.
Mar 27, 2008 | HP Photosmart 2575 All-In-One InkJet...
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart 2575 All-In-One InkJet Printer Logo
53 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
