Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
Fridiare dish washer
Wont do anything yes power is on
  • 5,911 Answers
Sounds like a blown thermal fuse. Most dishwashers have a thermal fuse mounted on or near the control board inside the console. There should also be a tech sheet inside the lower panel under the door that can help guide you. The thermal fuse should read a short. If it is open, it is non-resettable and must be replaced. I hope this helps you.
Posted on Jul 25, 2007
SOURCE:
How to start my dish washer
Check that the fuse or breaker for the DW is not blown or tripped. If not then likely you have a blown pump motor or something wrong with the panel electronics that fails to start your DW.
Feb 01, 2015 | Cars & Trucks
I have a Fridiare front loading washer. Water comes in fine and is pumped out but washer will not spin. Tried to spin by hand and wont budge. Any ideas?
Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight, spider pulley and belt. The counter weight is attached to the top of the drum and is known to loosen and fall to the bottom of the unit damaging the spider pulley. If the counter weight is attached to the washer drum and the belt is attached to the spider pulley and motor than you will need to check the voltage on the motor. If you do not have voltage to the motor than the control unit may be defective.
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
My dishe washer wont turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced
Now, if you have confirmed that the unit is receiving power from the outlet, and the unit is still not responding, this will lead to a failed control board, or timer module. replace either the timer, or control board, in this case.
Nov 05, 2009 | Dishwashers
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
May 26, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Maytag dishwasher cannot choose cycle on light panel
hello hmm ok so no lights it sounds like your control panel after unplugging your dish washer check the panel for loose wires the panel is the part behind were your buttons are located will have to remove your back cover to access this if that's all good then try your power cord again make sure its not got any loose wires were it attaches into the dish washer have a nice day and good luck let me know if you find anything.
Mar 19, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dish washer wont come on
there is a thermal fuse connected to the control board in the main console that is probable blown
Mar 01, 2009 | Dishwashers
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
327 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
