Question about JVSG IP Video System Design Tool
Ip video system design tool 7 key - JVSG IP Video System Design Tool
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
Tip
Run Commands
Do you use the Run feature in Windows?
Many computer users, don't even know that, there exist hundreds of commands, which can enhance your experience using computers..... and they are even useful to impress others with your knowledge in computers.
Nearly all of the Run Commands Correspond to a particular Control Panel Item or any utility or tool or task that can be accessed through Windows.
There are, however, tools and utilities that I bet you never knew you had that can be accessed through the Run feature.
The main reason most people don't use the Run feature is because they don't know the Commands.
So, to solve that problem, I decided to put together some most useful Run commands
First of all how to get run box
For XP
Click Start. Click Run.
For Vista / Windows 7
Press ** Windows key + R (** Windows key lies between Alt & Ctrl button)
& now, here's the list
Accessibility Controls : access.cpl
Accessibility Wizard : accwiz
Add Hardware Wizard : hdwwiz.cpl
Add/Remove Programs : appwiz.cpl
Administrative Tools : control admintools
Adobe Acrobat (if installed) : acrobat
Adobe Designer (if installed) : formdesigner
Adobe Distiller (if installed) : acrodist
Adobe ImageReady (if installed) : imageready
Adobe Photoshop (if installed) : photoshop
Automatic Updates : wuaucpl.cpl
Bluetooth Transfer Wizard : fsquirt
Calculator : calc
Certificate Manager : certmgr.msc
Character Map : charmap
Check Disk Utility : chkdsk
Clipboard Viewer : clipbrd
Command Prompt : cmd
Component Services : dcomcnfg
Computer Management : compmgmt.msc
Control Panel : control
Date and Time Properties : timedate.cpl
DDE Shares : ddeshare
Device Manager : devmgmt.msc
Direct X Control Panel (if installed)* : directx.cpl
Direct X Troubleshooter : dxdiag
Disk Cleanup Utility : cleanmgr
Disk Defragment : dfrg.msc
Disk Management : diskmgmt.msc
Disk Partition Manager : diskpart
Display Properties : control desktop
Display Properties : desk.cpl
Display Properties (w/Appearance Tab Preselected) : control color
Dr. Watson System Troubleshooting Utility : drwtsn32
Driver Verifier Utility : verifier
Event Viewer : eventvwr.msc
Files and Settings Transfer Tool : migwiz
File Signature Verification Tool : sigverif
Findfast : findfast.cpl
Firefox (if installed) : firefox
Folders Properties : folders
Fonts : control fonts
Fonts Folder : fonts
Free Cell Card Game : freecell
Game Controllers : joy.cpl
Group Policy Editor (XP Prof) : gpedit.msc
Hearts Card Game : mshearts
Help and Support : helpctr
HyperTerminal : hypertrm
Iexpress Wizard : iexpress
Indexing Service : ciadv.msc
Internet Connection Wizard : icwconn1
Internet Explorer : iexplore
Internet Properties : inetcpl.cpl
Internet Setup Wizard : inetwiz
IP Configuration (Display Connection Configuration) : ipconfig /all
IP Configuration (Display DNS Cache Contents) : ipconfig /displaydns
IP Configuration (Delete DNS Cache Contents) : ipconfig /flushdns
IP Configuration (Release All Connections) : ipconfig /release
IP Configuration (Renew All Connections) : ipconfig /renew
IP Configuration (Refreshes DHCP & Re-Registers DNS) : ipconfig /registerdns
IP Configuration (Display DHCP Class ID) : ipconfig /showclassid
IP Configuration (Modifies DHCP Class ID) : ipconfig /setclassid
Java Control Panel (if installed) : jpicpl32.cpl
Java Control Panel (if installed) : javaws
Keyboard Properties : control keyboard
Local Security Settings : secpol.msc
Local Users and Groups : lusrmgr.msc
Logs You Out Of Windows : logoff
Malicious Software Removal Tool : mrt
Microsoft Access (if installed) : msaccess
Microsoft Chat : winchat
Microsoft Excel (if installed) : excel
Microsoft Frontpage (if installed) : frontpg
Microsoft Movie Maker : moviemk
Microsoft Paint : mspaint
Microsoft Powerpoint (if installed) : powerpnt
Microsoft Word (if installed) : winword
Microsoft Syncronization Tool : mobsync
Minesweeper Game : winmine
Mouse Properties : control mouse
Mouse Properties : main.cpl
Nero (if installed) : nero
Netmeeting : conf
Network Connections : control netconnections
Network Connections : ncpa.cpl
Network Setup Wizard : netsetup.cpl
Notepad : notepad
Nview Desktop Manager (if installed) : nvtuicpl.cpl
Object Packager : packager
ODBC Data Source Administrator : odbccp32.cpl
On Screen Keyboard : osk
Opens AC3 Filter (if installed) : ac3filter.cpl
Outlook Express : msimn
Paint : pbrush
Password Properties : password.cpl
Performance Monitor : perfmon.msc
Phone and Modem Options : telephon.cpl
Phone Dialer : dialer
Pinball Game : pinball
Power Configuration : powercfg.cpl
Printers and Faxes : control printers
Printers Folder : printers
Private Character Editor : eudcedit
Quicktime (If Installed) : QuickTime.cpl
Quicktime Player (if installed) : quicktimeplayer
Real Player (if installed) : realplay
Regional Settings : intl.cpl
Registry Editor : regedit
Registry Editor : regedit32
Remote Access Phonebook : rasphone
Remote Desktop : mstsc
Removable Storage : ntmsmgr.msc
Removable Storage Operator Requests : ntmsoprq.msc
Resultant Set of Policy (XP Prof) : rsop.msc
Scanners and Cameras : sticpl.cpl
Scheduled Tasks : control schedtasks
Security Center : wscui.cpl
Services : services.msc
Shared Folders : fsmgmt.msc
Shuts Down Windows : shutdown
Sounds and Audio : mmsys.cpl
Spider Solitare Card Game : spider
SQL Client Configuration : cliconfg
System Configuration Editor : sysedit
System Configuration Utility : msconfig
System File Checker Utility (Scan Immediately) : sfc /scannow
System File Checker Utility (Scan Once At The Next Boot) : sfc /scanonce
System File Checker Utility (Scan On Every Boot) : sfc /scanboot
System File Checker Utility (Return Scan Setting To Default) : sfc /revert
System File Checker Utility (Purge File Cache) : sfc /purgecache
System File Checker Utility (Sets Cache Size to size x) : sfc /cachesize=x
System Information : msinfo32
System Properties : sysdm.cpl
Task Manager : taskmgr
TCP Tester : tcptest
Telnet Client : telnet
Tweak UI (if installed) : tweakui
User Account Management : nusrmgr.cpl
Utility Manager : utilman
Windows Address Book : wab
Windows Address Book Import Utility : wabmig
Windows Backup Utility (if installed) : ntbackup
Windows Explorer : explorer
Windows Firewall : firewall.cpl
Windows Magnifier : magnify
Windows Management Infrastructure : wmimgmt.msc
Windows Media Player : wmplayer
Windows Messenger : msmsgs
Windows Picture Import Wizard (need camera connected) : wiaacmgr
Windows System Security Tool : syskey
Windows Update Launches : wupdmgr
Windows Version (to show which version of windows) : winver
Windows XP Tour Wizard : tourstart
Wordpad : write
Note : Some of these commands, may only intended to use for XP only
on Jul 01, 2010 | Computers & Internet
How to find wpa2 key
Log into your router using a wired connection. To find the router's IP address you need to open a command prompt (On windows 7 and Windows 8 the easiest way is to hit Windows Key + R for the run command, then type in cmd and hit enter). Once in the command prompt type in ipconfig and hit enter, the gateway is the ip address you need.
Use the gateway ip address in your browser's address bar and it will take you to your router login page (login varies by device, check the router's manual). Once in the router, check wireless settings and under security it will show you what your wireless WPA key is currently set to.
Oct 17, 2013 | Microsoft Xbox 360 Console
How can I get the IP address for my system, 4CH H.264 Multiplex DVR?
To check the IP address, press MENU key on the unit and enter password to access OSD setup menu. Select <System Setup>, <Network Setup>, then <LAN Setup> to check the IP.
Jul 22, 2013 | Tsm Dvr8024 W/500gb 4-ch H.264 Digital...
How can i get an ip address
Firstly, what operating system are you using?
applicable for windows xp or windows 7. press Windows Key + R
select the appropriate network connection (e.g. Local Area Connection). Right click the Local Area Connection choose Properties. For windows xp, doble click Internet Protocol. For Windows 7, double click Internet protocol IPv4. choose Obtain an IP address automatically. press OK. right click again the Local area connection then choose Status. there tou can see that your computer is negotiating for an IP address from the dhcp server. if still cannot obtain an ip address, press Windows key +Run then type "services.msc". scroll down and find DHCP client. ensure that this service is running.
Please also try to check if the network you are connected does have a DHCP server.
Jul 01, 2013 | HP Compaq nc6220 Notebook
Windows 7 home basic product key for Product id 00346-OEM-8992752-50258
Windows 7 Home Basic with the key you provided is an Original Equipment Manufacturer (OEM) version of Windows 7. These versions are auto-keyed/auto-activated with a BIOS check when booting to the media to install Windows.
The only times it should prompt for a product key are:
  1. Installing the OS on a different brand system other than the OED brand it was designed to be installed on.
  2. Installing Windows from inside an already running install of Windows instead of booting to the Windows media.
If this is the OEM system the OS shipped on and you are prompted for activation, flash the bios to the most current version and run the Microsoft WGA tools to clear the activation prompt.
If this is not the OEM system the media shipped with, then you can't activate it.
If you installed Windows without booting to the Media, then boot to the media and re-install Windows.
If under warranty, contact the OEM warranty service as they provide support for OEM Windows.
Jul 20, 2011 | Microsoft Windows Vista Home Basic for PC
Dhcp: Discovery Option 128 missing. Linksys router. My mac is happy, just not my Mitel 5330 phone. Whatup?
Option 128 tells the phone where the phone system is. A linksys router isn't capable of giving this option out. Where is the telephone system? Is this a teleworker phone? if TW phone, press and hold the 7 key while booting the phone, and type the teleworker server IP address.
I recommend you contact your administrator or system vendor for guidance.
Dec 24, 2010 | Mitel 5220 IP Phone
My 1701 A.D. game does not work on my windows 7 operating system?
The game is designed to work with XP or window 2000. See attached as copied from their site: 1701 A.D.
Platforms: PC
Genre: Strategy/Simulation
ESRB: Everyone 10+
PC Release Date: October 2006
MINIMUM SYSTEM REQUIREMENTS
  • This product does not support Windows 95/98/ME
OS: Windows®XP or Windows®2000 English Version
CPU: 2.2 GHz Intel Pentium 4® or AMD Athlon 3200+
RAM: 512 MB
Hard Drive: 3.5 GB or more free space
Video: 3D Hardward Accelerator Required – 100% Direct X 9.0 compatible with latest drivers
Video RAM: 64 MB
Disc Drive: 4X DVD-ROM Drive
Sound Card: DirectX® 9.0 compatible
Multiplayer: Internet and LAN (TCP/IP) supported. Internet play requires broadband connection and latest drivers. LAN play requires network interface card with latest drivers.
Sep 11, 2010 | Aspyr Computers & Internet
Port forward
I am assuming that you are running the camera in a remote place that is NOT your home. (Such as work.)
Do you have access to the on-site location's gateway/router system? If so, make sure that you are logging into the camera's web interface.
Do the following:
1.) Assign a STATIC IP to the camera.
2.) Make sure you know the ISP's DNS information and enter it into the camera's config accordingly. (Typically, you can also use your internet connection gateway device as the DNS server for a device as well. ISP's DNS is more direct, however.)
3.) DESIGNATE A PORT NUMBER FOR THE CAMERA TO GO THROUGH ON YOUR ROUTER.
4.) Enable UPnP in the camera so the device makes itself known to any router on the network so it can dynamically open ports as needed. Video feeds may or may not work without this.
5.) Save your configuration of course.
6.) Login to the on-site router of the network that your camera is connected to.
7.) Go to NAT/Port Forwarding/Whatever it's called in the router...and make an entry for the camera's designated STATIC IP. Make sure that you get the right port number on the entry as well.
8.) Save your configuration.
Optional step: If your ISP is not using a STATIC IP for your internet connection, then use a Dynamic IP site such as http://www.dynip.com to help dynamically adjust for sudden or regular IP changes of your network's internet connection. (That way you can also just type in a URL and port number for your camera instead of memorizing an IP.) Note: This may require you to install software on a local system to update the DynIP site with your current WAN IP. (The camera appears to have the ability to do this on it's own, however. Find the options in the camera's web interace.)
If you have followed these steps in general and adapted to them where necessary...you should have a working video feed from the camera...
...unless you ARE using a network connection at work for it and your administrators have locked out certain network functions that the camera is requiring.
In that case...
...contact your system administrator for assistance. LOL
Cyryl
Oct 31, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
622 people viewed this question
Top JVSG Computers & Internet Experts
David Payne
David Payne
Are you a JVSG Computer and Internet Expert? Answer questions, earn points and help others
