Question about Vehicle Parts & Accessories
My car alarm keeps going off. Can I remove the fuse and where is it?
    Genius:
  • Vehicle Part... Master
  • 1,669 Answers
There is a fuse and it is in the fuse box under the hood.
Posted on Jan 22, 2013
How can I deactivate my car alarm, it keeps going off everyday
alarm keeps going off - Acura Forum : Acura Forums
www.acuraworld.com > ... > CL > 1st Gen CL
Jun 6, 2011 - 8 posts - ‎4 authors
Now the alarm is suddenly going off when I put the fuse back in. ... I am going to print it and keep it with my stuff in my Acura folder. ... as i connect the battery terminals and wont turn off with the remote. can you help me on this one please? ... Join Date: Sep 2012. Posts: 2. Car 1: 1998 Acura 2.3 Cl. alarm ...
1999 TL Deactivate Alarm/pull the fuse - AcuraZine Community
acurazine.com/.../problems.../1999-tl-deactivate-alarm-pull-fuse-746888/
Oct 4, 2009 - Is there a way that I can deactivate the alarm on my car. ... It is very annoying, especially when it goes off for no reason in the .... My 2001 CL black box has 4 relays, 2 grey, 2 black.removing any and ... Troubleshooting Fail: Stuck Drivers Window, xsilverhawkx, Problems & Fixes, 5, 09-28-2015 07:51 PM. 2005 TL, HFL Malfunction and Parasitic Draw
May 7, 2012
2012 TL Remote Starter
Jul 15, 2011
99 acura tl stuck in park and brake lights won't work
Aug 25, 2010
1999 Acura 3.2TL shuts down on its own
Jul 20, 2009
More results from acurazine.com
Jan 08, 2016 | 1998 Acura CL
How to disconnect the alarm
Depending if it is a aftermarket or a factory alarm, they should all have fuses that can be removed. By removing the fuse, you may lose your keyless entry option. Most aftermarket alarms have a siren that is usually mounted under the hood in the engine compartment area. I've seen where people have cut the wire going to the siren to disable it but keep the power going to the alarm system to keep the keyless entry still functional if it came with the alarm system.
Factory alarms usually use the existing horn for the alarm. If that is the case, you might need someone who is experienced to disable the circuit so that the horn will not sound if alarm goes off but the horn will still be functional when needed. Hope this helps.
Dec 20, 2014 | Cars & Trucks
My alarm system keeps going off and I would like to turn it off.
Hell,
There has to be a separate fuse for the alarm system look in your fuse box or under the hood usually near the firewall jus remove the fuse if you find it this will take care of your problem
Oct 15, 2014 | Dodge 2005 Stratus SXT
2000 Hyundai Elantra car alarm problem. I was in a fender bender and ever since then the alarm will go off randomly when locked. I took the fuse out of the box that stopped the horn from blaring but the...
Try YouTube. Type disable car alarm or car alarm keeps going off. You'll find several videos of people fixing alarm malfunctions.
Good luck. Hope this helps.
Oct 02, 2017 | 2000 Hyundai Elantra
Alarm keeps going off. what is the problem which fuse can i remove?
it is most likely going off because the sensor that sets the alarm off when someone bangs it or breaks the window is set to sensitive. Locate the adjustment under the hood near the firewall usually on the alarm module and turn it down.
Sep 19, 2010 | 2005 Chevrolet Cobalt
Hi there, The car alarm on my 2007 Camry keeps going off randomly. I don't really want a car alarm. How do you disable it? Thanks, Richard
can you check under hood, there is a fuse box, remove fuse box lid, inside is printed names of circuits if you have an alarm circuit , remove that fuse, then check if car starts and runs, if so, alarm is disabled.
Jun 13, 2010 | 2007 Toyota Camry
Acura cl alarm problems???
To all you Acura alarm sufferers. In the immediate term to appease your neighbors - open the door and reclose, leaving the door ajar enough that the interior door light is still on. Be sure to turn off the roof light so no one is cued your car door is ajar.
When you can go under the hood, remove the fuse - I think it is 15 - the fuse box cover has a diagram. I left the fuse out for a couple of hours and reinserted it. That broke the pattern for 7 months.
It is 89 degrees in chicago today, the alarm went off at the train station and I got a ticket for noise disturbance.
It's time to look at the fuse box again. i think extreme temps are the problem.
Mar 10, 2010 | 1999 Acura CL
I wa schanging a tail light on a trailor attached to 1996 Bronco must have shorted something. Now all sorts of problems 1 won't start 2 alarm keeps going off no turn signals n no brake lights Can't...
Remove the in-line fuse for the alarm. If the alarm faulted out it is activating the starter kill switch and the lights issue is the alarm trying to flash the lights.
Sep 12, 2009 | Ford Bronco Cars & Trucks
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
