Question about Cakewalk Music Creator 4
Playback is to fast
When i record somethin it records just fine then i hit stop. the clip automaticaly cuts down to half the size then when i play it back it is way to fast and high pitched please help me
  • 22 Answers
Oh wow dude,
it sounds like your bit rate and sample rate are out of whack. You should shoot an email to tech support cuz this is gonna need some more in-depth help than i can really get into here. But check your bit depth and sample rate first. They may be out of sync
Posted on Mar 05, 2009
My g9 was playing video clips very fast. i changed the setting back to "standard" and can record/play new videos correctly; however, the video clip that i previously recorded before i changed the setting...
I believe the setting you changed set the RECORD method, not playback. The video is recorded that way. There are some Video software out there that can rerecord a video at a slower pace, but do you want to spend the money? Try Ulead.com for a low cost program.
Apr 17, 2010 | Canon PowerShot G9 Digital Camera
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Machine appears to record per instruction manual but will not play anything back and the instruction manual includes NOTHING on playback except to hit STOP when we're through recording, back up to the...
it appears to be recording but is it really?
when you are recording there are two levels you should see moving up and down on the screen. the input volume and the recording volume per track. dont forget to arm the track. tascam has a silly way to arm the track on some of there unit. its combination of buttons. something like hold down the record button and press the track arm button then release both. when youre ready to record press play.
Feb 22, 2009 | Tascam DP01 All-In-One Recording Package...
When i record somethin it is fine but when hit stop recording and
check out what sound card you have,then make sure that your card name is sloted as you playback output
Jan 27, 2009 | Cakewalk Music Creator 4
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
Midi playing is
This is specific to AcidPro.
If you doubt, check the same at your friends PC/Laptop.
You will then be sure what i told.
May 23, 2008 | Computers & Internet
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Cakewalk Music Creator 4 Logo
67 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
