Question about Nextar MA933A MP3 Player
Music not found
I have a nextar ma933a-1p and the songs are not there that i uploaded to the player after i disconect from the computer
  • misicmom Jan 29, 2009
    I thought I had downloaded music but now cannot find anything. Lost instructions. Know how to turn on but from there I am lost.
  • 8,596 Answers
The songs you are trying to load to the Mp3 player are not compatible with the Nextar - a good test for this would be to connect your Nextar to the PC, open Windows Media Player, and click the Library tab, then the Sync tab - if a little blue "i" appears next to the song, it will not work with your Nextar. In fact, any song that is not in mp3 format or unprotected WMA (very few WMA's are unprotected unless you Ripped them directly from CD) will not play in the Nextar.
-Tha Mp3 Doctor
Posted on Feb 05, 2009
I can't get my mp3 player to work. is a nextar ma933a-1p. i plug it to the usb port but when it opens there is nothing there and when i try to add music it won't allow it.
you might have accidentally turned on the security on it..... the simple way to turn those settings off is to go to the properties of your mp3 player and there should be a tab with security or just look under all the tabs and see if there is a security feature on
Jan 15, 2010 | Nextar MA933A MP3 Player
Nextar MA933A-20P will only play factory installed files.Music files add are present but will not play. Will only shuttle between classical and fast dance files
The following may help:
1) Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format)
2) Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. 3) If you have uploaded your songs with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player) ps. To reformat your Music files to the player acceptabel format, you need to download and use a 'Audio Media Converter'.
Dec 20, 2009 | Nextar MA933A MP3 Player
When i plug my nextar mp3 player item # MA933A-1P into my computer ( i'm running Windows Vista). it says software downloaded but it's not connecting to Windows Media Player so I can download my songs to...
Just Drag and Drop your MP3 files onto the drive tht was created. Look in "My Computer" for "Removable Disk", double click on it,then copy your MP3 songs from your music folder (right click, copy) and paste them (right click, paste) into the MUSIC folder on the "Removable Disk"
Nov 16, 2009 | Nextar MA933A MP3 Player
How do I add songs to my mp3 player?
yes you can your mp3 player can play both wma or mp3 types of format so if you have songs in your windows media player or you have a other sorce that you use to play your music with you can upload your music to your nextar,it should have came with a usb cable plug 1 end into your nextar and the other end into your computer to upload any of your downloaded music including any music that you have stored on your computer off cd's or and music that you got off the internet.
Mar 11, 2009 | Nextar MA933A MP3 Player
Need to erase files on nextar ma933a mp3 player
using hte mp3 player, open play the song for a few seconds, then pause it.
press menu.
move to delete file and press menu.
move to yes and press menu.
it will be deleted.
Mar 06, 2009 | Nextar MA933A MP3 Player
Can't load songs on nextar mp3 1 GB ma933a- 1p
There are several possibilities:
1) The songs you are trying to load to the Mp3 player are not compatible with the Nextar - a good test for this would be to connect your Nextar to the PC, open Windows Media Player, and click the Library tab, then the Sync tab - if a little blue "i" appears next to the song, it will not work with your Nextar. In fact, any song that is not in mp3 format or unprotected WMA (very few WMA's are unprotected unless you Ripped them directly from CD) will not play in the Nextar.
2) You have the Hold switch engaged - unlock it
3) The PC's you are trying to connect it to are running Windows Vista - not compatible with Nextar
-Tha Mp3 Doctor
Jan 31, 2009 | Nextar MA933A MP3 Player
Adding music to player
If your mp3 player truly is a Nextar MA933A - which I doubt - you can't do it directly. You would have to transfer the songs from your SD card to your PC, and then move them from your PC to the Nextar.
-Tha Mp3 Doctor
Jan 29, 2009 | Nextar MA933A MP3 Player
Is there anyway to upgrade the Nextar MA933A MP3 Player
free software to convert m4a to mp3 files:
Try the dbpoweramp music convertor.
Run it > Choose file
http://www.dbpoweramp.com/codec-central.htm
That page is the codec page; choose which one you want, in your case:
http://www.dbpoweramp.com/codec-central-mp4.htm
for the mp4 codecs (i.e. aac).
Note: if you download songs from the iTunes Music Store, they will be protected files, ending in .m4p (p for protected). It is quite within your legal right to unprotect these if you so wish: http://hymn-project.org/ that program will do that for you. You can't convert songs that are protected.
A little practice and it'll be second nature :)
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Nextar MA933A MP3 Player
Downloaded music, all titles converted to chinese?
i have a nextar ma933a mp3 player trying to download songs from my apple computer from itunes please help me its for my 4year old son he is so excited but i have no idea how to make the darn thing work so please please help me.
Jan 31, 2008 | Nextar MA933A MP3 Player
Nextar ma933a
I think I fugured it out. I think this should set the thing up for you. Turn the unit on. Push the button in and hold for the count of three. Wait as you count to two then push the buton in quickly. The screen should display a different "MUSIC" sign. Now the tiny file type in the upper left of the screen should say "mp3". Now make sure you are loading mp3 files. Be sure the unit is ON when you connect it to the USB port. Drag and drop files onto the mp3 player. I got it to accept 5 songs so far. I am working with Windows xp. Hope it helped!
Dec 26, 2007 | Nextar MA933A MP3 Player
Nextar MA933A MP3 Player Logo
111 people viewed this question
Top Nextar Audio Players & Recorders Experts
topcat7736
Level 1 Expert
Joseph Hoffmann
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
