Question about Audiovox SIR-PNP3 SIRIUS Radio Receiver
My radio is showing aquiring signal.how can i get it fixed
Where can i get my audiovox sirius receiver fixed
    Problem Solver:
  • 10 Answers
I heard these have a common problem with the antenna line breaking within the radio. I had it happen and replaced the radio. It's a shame since I'm sure I could have fixed it. I think it happens if the radio ends up hanging from the antenna lead. Any electronic tech or engineer should be able to check continuity from the antenna jack and find/fix it.
Posted on Dec 16, 2013
3 Suggested Answers
ronaldsuboc
  • 449 Answers
SOURCE: no sirius id, no presets, all cleared... activation didn't help
hi!!!
try to check the antenna
may is not connected
or the second solution
try to bring in the service center
near you
Posted on Oct 31, 2008
TOLhamRadio
  • 509 Answers
SOURCE: unit shows 3 bars for signal strength yet the
This is a very old radio, and your antenna could be shot too. Try another antenna first.
Posted on Mar 03, 2010
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Jan 06, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
The dispaley states "aquiring antenna" but never finds it,can this be fixed?
Yes. However, it depends on what is causing the acquiring signal message. It could be that you just have to replace the dock or antenna. But it could also mean the unit is going bad, in which case it would need to be repaired. www.tss-radio.com has a repair guy, though with that unit being discontinued for as long as it has, he may not have parts. You may have to search around for a replacement on amazon or ebay.
Jun 01, 2012 | Sirius Satellite Radio Sirius Sportster...
My radio recently just says aquiring signal...it never does. What is wrong
I used a solution from another post on this site. Use heat gun to heat pc board after removing tuner assembly. Take care with the amount of heat used.
Sep 14, 2011 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Unit shows 3 bars for signal strength yet the
Mar 01, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
The audio cuts in and out intermittently
IT COULD BE ONE OF UR SPEAKER WIRE A TOUCHING AND GROUNDING OUT LOOK AT UR SPEAKER. AND IT COULD BE ONE OF UR SPEAKERS IS CONNECTED WRONG WITH THE POSITIVE ON THE NEGATIVE CHECK THAT OUT TOO ALL SPEAKERS NEED TO BE POITIVE WITH POSITIVE AND NEGATIVE WITH NEGATIVE
Jul 04, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Acquiring signal
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
Dec 17, 2008 | Sirius Hoods Stiletto SL100-PK1 Satellite...
Sirpnp2 reciever gets hot and loses signal.
I had the exact same problem with Sirius radios. I bought two Kenwood DTS-7000S receivers and both were sent back for warranty. Of the two, they only fixed one but by the time I figured out the other was bad, it was out of warranty. Kenwood, along with the repair community state they do fix such units, they toss them out. The thing that gets hot hot hot is the part that receives the Sirius antenna inside your unit. If you're like me and have nothing to lose then I recommend doing some cutting with a dremel and adding a small computer fan. It just takes a light breeze to keep that part cool enough (but it does take some sort of breeze, convection is out). For a home unit, find an old A/C power supply and match it to an old computer fan of equal or less voltage. For car, find a fan that uses 12 volts or less. It's an easy fix, really!
Nov 04, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Acquiring signal
My wife replaced the car kit.
The sportster itself was fine, what fixed the problem was replacing the cradle.
Now the second one has taken a dump.
May 21, 2008 | Sirius Satellite Radio Sirius Sportster...
Asquiring signal
yes everyone is getting "aquiring signal" problem, why isn't sirius radio taking responsibilty ???? it's thier satttelite ??????
glenn
Nov 10, 2007 | Sirius Satellite Radio Sirius Sportster...
Audiovox SIR-PNP3 SIRIUS Radio Receiver Logo
134 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
