Question about Pioneer DEH-P6500 CD Player
DEH X 6500 DAB
External DAB aerial fitted. Set says no signal. FM /MW ok as different aerial. Can you advise on how to tune DAB radio
drsinister69
  • 2317 Answers
SOURCE: Set clock on car radio.
Here is a link to the owner's manual for the stereo which will tell you how to set the time:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1800.PDF
Posted on May 22, 2010
Testimonial: "Feedback was perfect. It solved my problem and answered even more as I read the manual. Thanks for the help. George Haggerty Jr."
danjoethurau
  • 20 Answers
SOURCE: setting radio stations on pioneer DEH-525R CD player
Scroll to the station then press and hold the preset button.
Posted on Aug 07, 2008
danjoethurau
  • 20 Answers
SOURCE: setting radio station to a channel on a Pioneer DEH-525R cd player
Scroll to the station then press and hold the preset button you want it to goto.
  • 124 Answers
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
Posted on Dec 27, 2008
xxchemlight
  • 144 Answers
SOURCE: pioneer ECQ MOSFET 50wx4 DEH-6500 Need manual
here hopes this helps ya click on the onwers manual half way down.
DEH-6500
Posted on Mar 24, 2010
Why will my radio new 3120 not pick up dab stations at all really tune and all I get is radio 2 have tried for a week to get magic fm thank you
If you have replaced a normal car radio with a DAB then your existing aerial is not suitable due to the required frequency range. You need a DAB aerial for cars. There are many types available, internal or external. Don't bother with converters as this will only give a marginal boost to the fm aerial.
Jun 06, 2016 | Cars & Trucks
FM radio stations
An aerial 9antenna) problem maybe cableproblem its grounded for FM [ just connect a single antenna wire on the core to test] mw its some times with a ferrite rod on the back side of the radio can get better may be it can sometimes be unfolding.
Jan 23, 2016 | 2009 Mini Cooper
I bought a Bush digtal/ AM/ FM radio ("retro transistor" style). DAB reception dropouts lasting several seconds each time have started occurring recently. AM/ FM is ok.
Constant usage of DAB should not cause it any damage ever. The dropouts are very characteristic of a poor signal reaching the DAB tuner, as digital is either there, or not there, nothing in between.
Check the aerial connection if any, the rod antenna if any, and try moving the antenna (whatever it is) to a better location, usually higher up, away from thick walls, and away from speakers if any.
Apr 18, 2015 | Grundig FR200 AM/FM/SW/DAB Radio
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
I recently moved my Legato Pure radio, now I have trouble tuning in the DAB radio and the display struggles to set the clock often flashing with a message saying it is wating for time to set. When it does...
Clearly, the DAB signal strength is poorer in the new radio position. Try moving it, even a foot or two can make a difference. Better still, use a roof aerial.
The display can be changed, even in standby mode - press the Display button to see the 3 options.
Dec 19, 2009 | Audio Players & Recorders
FITTED A SONY CDX-DAB6650 RADIO BUT WHEN IT CHECKS
yes you prob will do as you need a very good signal for dab radio the one supplide is like using a wet peice of string ie not very good
Oct 12, 2009 | Sony Car Audio & Video
How to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Feb 29, 2008 | Audio Players & Recorders
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
Pioneer DEH-P6500 CD Player Logo
392 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
