Question about Video Game Consoles & Games
Car'nt get on to gamecolany
Gamecolany will not open
    New Friend:
  • 17 Answers
Try to fix you internet engine
Posted on Jan 23, 2013
94 camry alarm would'nt stop i pulled a black wir next to the horn now car wont start
the wire from the horn is part of an imobiliser so it wont start replace wire it sounds like imobiliser battery or alarm pad if wont turn off
Oct 13, 2012 | Toyota Camry Cars & Trucks
Battle Realms could'nt read INI file
cant save the ini file says access denied
Jun 12, 2012 | Ubi Soft Battle Realms
Why my crown ultra tech 2020 fan does'nt spin
Airflow may be adequate throughit not to need it. The other possibility is the fan is dead or thermistor on the heat sink is open. If it shuts down or starts to clip the signal real bad, it needs to be looked into.
Jan 17, 2012 | Cars & Trucks
When I push the gas on my car it won't go past
The car runs fine after it warms up? Is it running with the check engine light off? But it does come on with the key before the engine is started? If the coolant temperture senser is bad ( or disconnected someway) the check engine light will be on but the car might run OK at normal operating tempertures. Have the car checked for codes. It's OBDI so you might have to find a service provider that can ceck the codes on this pre OBDII car. If it turly runs good at normal operating tempertures and the transmission is'nt low on fluild then the coolant senser does'nt always turn the check engine light on if it's bad and still reading something but wrong. Truly running good and the coolant is full ( all the way). chage the senser and see what happens as thier cheap and easy to change with commn hand tools.654437604.jpg
Aug 24, 2011 | 1994 Ford Escort
Alternator is not charging but the local parts store tested it and it is working fine, all fuses are good
what makes you think its not charging? alternators should always be checked ON THE CAR.
Aug 03, 2011 | 1999 Oldsmobile Alero
The car shifting down when I drive it and don't know why ?
Hi. When you climb a hill it will shift down and when you over take someone (pass). That is why it is called an automatic. Any time you put your foot to the floor it will shift down.
Jul 27, 2011 | 2002 Kia Sedona
I have a Pentair MiniMax NT. I am getting ERR on the display but I can't seem to get the door open. I have tried turning the single screw that locks the left and right door but it won't unlock.
sometimes the door is just stuck. try pulling the door as you turn the locking screw. sometimes you need to use a flat head screw driver to help the door open as you turn the screw back and forth
Jun 11, 2011 | Pentair Minimax NT Heater
Need to know the wiring sequence between the coil and the icm someone removed the coil prior to my purchase of the car trying to install new coil 1987 Buick LeSabre 3.8L or 3800
The stock wiring harness harness just plugs into the end of the ingtion module and the coil sits on top of it, It sounds like you don'nt have the intion module and you might not have the platform that it sits on as when thier sold used at the junkyard the coil pac and the module are sold together along with the platforn. 93387599.jpgThis is just one of the 3 coils used or yours could be the Magnavox system763264510.jpgIt bolts to the module too but it wires to the module1063625834.jpgThese tabs you see connect to the module and the wires don't show as it bolts directly to the module. one side is all linked together as ground and the other side are the three cyclinder pair wires.274381877.jpg506424588.jpg24214799.jpgThis is the Magnavox, any Gm dealers parts dept can tell you which one yours came with but you'll need to give them the VIN so they can figure which one it was built with.370864813.jpgThis is the one that the Delco single coils bolt to, notice the tabs that stick out the bottom that the three coils bolt to The plug will fit to both but the delco setup costs a little less. It's best to buy this peice at a junk yard as if they took it off the motor or other system might not be working also and you'll have alot of money in it and it'll still not run. These engines were well known for the timing chain to go out then the cam signal does'nt tripper the conputer at the right time and the car won't run. Most of these cars are gone because of the cost of doing this kind of repair work they just junk em when this problem happens as it's worth more that the car to fix it. The mag navox coil is over 80 bucks the module is 80 bucks too if some one cut the plug off too them the plug cost 125 bucks and my store does'nt have it The delco coils cost 86.01 for three. As you can see the parts you don't have are worth more than this car is worth running on the open used car market. The cars worth 200-500 dollars and is driven by the price of scrape metal.
Apr 12, 2011 | Buick LeSabre Cars & Trucks
Video Game Consoles & Games Logo
14 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
