Question about Dewalt DPD3300 Commercial Pressure Washer
My dewalt dpd3300 ,why is it getting gas in the oil
I tried to start it and gave up. the next day I found all the gas somehow drained into the engine oil.
  • Dewalt Master
  • 885 Answers
This happens when the gas needle valve in the carburator sticks open. With it open, gas continues to flow into the carburator then into the cylinder and finally down into the crankcase. It can be caused by dirt in the needle valve's seat, a stuck needle or float. Most of the time you can remove the float bowl and flush out any dirt. If there's a lot you should consider flushing the gas tank and check your gas can for dirt. If the washer has been sitting for a long time the problem could be varnish is gumming up the carb works. Carb cleaner works well to flush that out. If the float, needle or seat is damaged you'll have to rebuild or replace the carb.
Posted on Jan 23, 2013
Gas somehow getting in the oil
i have no idea what you are working on here but i suspect power equ of some sort. your carbs inlet needle and seat are leaking fuel and thats how its gets in the oil.
Sep 11, 2017 | Genuine Motorcycles
Operating instructions
The Instruction Manual for the Dewalt DeWalt DPD3300 3300 PSI 28 GPM Commercial Pressure Washer can be downloaded from the following site:
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DPD3000IC
Scroll down in the Downloads box to the desired item; select the icon under PRINT DOCS to open.
Mar 06, 2011 | Dewalt DPD3300 Commercial Pressure Washer
Dewalt /Emglo 10 gal ,150 psi with 5.5 Honda GSX just shuts off sometimes ,some days it works fine ,some days it wouldnt work at all ,looks like something with gas ,it would shut off after pumpin tank...
I have an Emglo compressor with a 8 HP Honda motor. The motor has a low oil level shut-off switch in the crankcase. My switch failed intermittently and the motor would run sometimes and not others. There is a wire going directly into the motor crankcase. On my unit, the switch is normally open and when there is enough oil in the motor, it closes to allow the engine to run. If you can't start the motor, unplug the wire that goes into the engine from the connector. Then stick a wire into that connector and hold it to metal on the engine & try to start the motor. If that switch is the culprit, it should now start.
Be advised that running the motor without the switch in the circuit would allow the motor to be run with no oil in it.
Dec 06, 2010 | Dewalt Heavy - Duty 5.5HP, 10.5 Gal., Gas...
I would like to know if this pressure wahser use only gas or (Gas and Oil) is mixed?
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
Oct 15, 2010 | Dewalt DPD3300 Commercial Pressure Washer
Engine does not start easily after shut off
if there is water pressure still hooked up then pump is primed and a sensor { that kicks the idle down when not pulling the trigger} is restricting the fuel flow. see if problem continues without pressure
May 03, 2010 | Dewalt DPD3300 Commercial Pressure Washer
HOW MANY CFM DOES THIS COMPRESSER DELIVER AT 100 PSI
If this is the compressor the amount is 16.2 at 100PSI. PLease see attached link:
http://www.toolfetch.com/p-d55275.shtml
I hope this may have helped,
Tom
Oct 16, 2009 | Dewalt D55275 8 Hp Gas - Powered 17 -...
Sounds like a loud leaf blower, no engine sound.
You can get a rebuild kit from DeWalt for about $40 and fix it yourself. The flappers are most likely bent.
Jul 21, 2009 | Dewalt d55151 factory reconditioned emglo...
Dewalt DPD3300 Commercial Pressure Washer Logo
95 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
