Question about Car Audio & Video
Need a Manuel for footprint omniphonics amplifier 300 a
This is a rack mount amp
2 Suggested Answers
  • 5603 Answers
SOURCE: Would I need a mixer or amplifier with this
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Posted on Aug 20, 2011
Technical support for gli pro rcx5000u hibryd amplifiers
There is an email address here... https://www.glipro.com/contact_us.asp
Jul 04, 2014 | Nil GLI Pro RCX 5000 2000W Rack Mount 4...
The power off
need much more info to help. $300 amplifier made in china with stamped surface mount components. Have fuse and transformer thermal cutout tested, if these work then throw the amp out as it is darn near impossible to repair these things.
Mar 22, 2014 | Technical Pro Ax3000 3000 Watt 2 Channel...
My amplifier is to hot then off
use compressed air to blow dust out of unit, If it gets hot under no load condition you have a bad diode and resistor on one channel. A complex repair on this amp for an experienced tech. Probably more economical to replace it( for your next pro amp i'd recommend crown or qsc).
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
How do i get the most watts possible from this amp, with out overheating the amp.
you can run your amp at 1 ohm you would need to to have the right ohm subwoofer wired in parralle to get 1 ohm at amp ...... the put a 12 volt fan in the area to keep the amp cool so it doesnt over heat if you plane to
Audiobahn A2X400HQ 2 Ch Amp
1600w x 1 @ 1ohm - 800w x 1 @ 2ohm
600w x 2 @ 1ohm - 400w x 2 @ 2ohm
2-Channel High Current Amplifier -- Ideal for use with all Audiobahn Rack Mount Products
http://www.tintingbyfredjohnson.com
Dec 27, 2010 | AudioBahn A2X400HQ Car Audio Amplifier
How do you install the rear rack ears
I don't know about the Peavey amp but most have rack holes that run parallel with the amp's side panels. On the rear of the rack this requires a mounting kit unique to your rack (provided there are mounting rails present) or some creative strapping to properly stabilize the amp. I've seen tech's anchor the rear mounts to the inside of the rack walls. Wood is easiest (and strongest) to work with but fiberglass mounts with fender washers also creates a pretty strong mount....G.
Dec 06, 2010 | Peavey Pv 2600 Power Amplifier
Can I use these to Power 2 x 200 w 8Ohms
I think you should, the power supply could cost up to that price ( for a good one 13.8v ) and you could have a ground problem for the amps, humming sound if not properly ground.
Your welcome.
Dec 05, 2008 | Sony XM-222 Car Audio Amplifier
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
