Question about Acer Aspire Computers & Internet
Acer aspire 5552 bios update - Aspire Acer Computers & Internet
5 Suggested Answers
SOURCE: Acer Aspire 1640Z BIOS problem
Dear all,
I also posted this one under "Notebook Bios Problems" which might notbe the correct place. Anyway here it is for you to see and maybe youcan learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS shouldI use i.e. how do I know if I need the AT or UMA version - how toverify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started icon_sad.gif but later I was all smiles icon_biggrin.gif icon_biggrin.gif
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
Posted on Jan 13, 2009
  • 18 Answers
SOURCE: Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
Posted on May 04, 2009
drifterK
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
quick geek
  • 25 Answers
SOURCE: how do i take out the hard drive on a acer aspire
turn off the notebook
make sure all the cables are disconnected
flip the laptop
on the bottom look for a compartment
the compartment has a picture of stack of 3 cds,like circles
remove the screws of the compartment
look for a silver or a black colored box(hard drive)
remove the cover on top of the hard drive
take the hard drive out carefully
when you replace it make sure everything is kept correctly
Posted on Feb 25, 2011
Acer aspire 5552-7819 laptop does not
Not sure what you mean, but if your sd card is not being recognized by your laptop it could mean you need to reinstall your drivers.
Before doing this try using a different sd card incase there is a problem with the one you are using.
Jul 17, 2014 | Acer Aspire Computers & Internet
Acer Aspire 5552-3691 Screen Wont Come On
Have you tried re-seating the memory, if yes and still not booting then it is most likely the mainboard as it was the most common faulty item with this series.
Jul 10, 2014 | Acer Aspire 5552-3691-24271 Laptop
Is AVG compatable wit aspire 5552-3691
Yes. I use AVG on both the Acer laptops in our household
May 09, 2014 | Acer Aspire 5552-3640, 5552-3691,...
Acer aspire 5552 completely dead no power lights or nothing, my charger works fine.
Please remove your hard drive and reboot your laptop. If your laptop displays the BIOS screen, then your hard drive is dying or dead. Also, unplug the main battery to test it.
Feb 28, 2014 | Acer Aspire 5552-3691-24271 Laptop
Flash the bios
DO NOT FLASH THE BIOS PROGRAM
Not trying to be rude, making a statement
Tell me about this laptop.
What is the model name, and model number?
Example, Acer Aspire 5552
Model number is on the bottom of the laptop.
Just black screen one day?
Had problems leading up to it?
Post back in a Comment.
Regards,
joecoolvette
[1) When flashing the BIOS, and power goes off?
You're DONE, unless when asked you saved a copy of the original BIOS; to go back to.
2) Wrong BIOS update? (Flash the BIOS)
BIOS update too new, or not compatible?
You're DONE unless you saved a copy of the original BIOS.
Too easy to turn that laptop into an expensive paperweight.
It is a fact that about two weeks after a laptop, or desktop computer hits the market; that there is an updated BIOS program for it.
But read the above again ]
Apr 02, 2013 | Acer Aspire Computers & Internet
Where can I get manual for Acer Aspire pew76
I understand that the Acer Aspire 5552-5619 is a PEW 76.
If this holds to be true, then manuals for the Acer Aspire 5552 series of Notebook PC's, is what you want,
http://us.acer.com/ac/en/US/content/drivers
Under;
1) Select Product Family, click on Notebook, Ultrabook.
2) Select Product Line, click on Aspire.
3) Select Product Model, scroll down; click on 5552
Under the Supported OS heading it will state Windows 7.
A brief pause, the a small window will pop up, asking whether you have Windows 7, or 8.
Click where needed, then click on the Document tab.
( Application / BIOS / Document / Driver / Patch )
To the left of Generic UG, click on the white down arrow in the Orange square.
The Quick Setup Guide has info also.
Regards,
joecoolvette
Mar 06, 2013 | Computers & Internet
My Acer 5552G won't turn on.
try a system reset see below link
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 20, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
Acer aspire 5552 completely dead no power lights or nothing charger works fine
try replace your power adapter,i think that problem in ur power adapter
,,try it
May 30, 2012 | Acer Aspire 5552-3691-24271 Laptop
Computers & Internet Logo
234 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
