Question about Taylor Ice Cream Makers
Taylor 794 machine won't freeze yogurt
There is no freezer operation after pressing the AUTO key. The Unit is plugged in, there isn't a fuse blown, and I have tried to reset the freezer but none of these things work. What could be the problem?
    Genius:
  • 1,669 Answers
Try these sites:
http://www.taylorproducts.net/Inside/FAQ.aspx
The thermostat has gone bad or the refrigerant charge is low...check the thermostat to make sure that it is calling for the refrigeration system to run, make sure power is getting to the compressor and then make sure the compressor is cooling properly...
If compressor is running them the t-stat is okay and there is a problem there....is it is cycling on and off then the t-stat is bad.....
if it is running continuously then you probably have a refrigerant leak...it needs to be found, fixed, and the system recharged...
Posted on Jan 22, 2013
4 Suggested Answers
  • 1169 Answers
SOURCE: need to know how to clean the taylor soft serve
http://www.taylor-company.com/
go to this web site and just click on operators manuals. Then either enter your model number or you can use the drop down menu.
Posted on Aug 12, 2010
  • 30 Answers
SOURCE: taylor 751 sp dead
Sound like you might have a loose wire or ribbon cable,might even be a loose wire on switch.Be sure to turn breaker off to machine and unplug it before you check them. Also check the motor reset.
Posted on Mar 07, 2009
SOURCE: Where can I find a repair man for Taylor Frozen
Call toll free number 1-800-665-1125 or www.dslinc.com and they will tell you who you can get in your area. The name of the company who services Taylor is DSL
Posted on Apr 19, 2010
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Aug 01, 2016 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Why my Taylor yogurt machine not freezing the yogurt. Model number 339 -58
if cooling light is coming on ck to see if chill plate is getting cold after a few minutes , also visually verify that agitator blades are moving mix around and over chill plate
(chill plate is inside round tunnel that mix bars go thru )
Jan 21, 2016 | Taylor Ice Cream Makers
I have a Taylor 794 soft serve machine. The left side is too soft.
Viscosity adjustments should not have to be made frequently on these machines. If you change products a lot, such as flavors of yogurt, minor adjustments may be required. If your machine uses 3 phase electricity and it machine has been moved or any electrical work performed you may want to check the beater rotation, the beater should rotate clockwise inside the barrel viewing from the front, if you look at the gear box from the back, the pulley should be turning clockwise as well. Otherwise, there is a fine tuning potentiometer on the control, you must remove the front cover to see it. Clockwise is colder/thicker. I recommend small adjustments. It is best to read the amp draw on the motor to see what type of amps it is drawing. If your mix is soft and your motor is drawing 4 amps, you may have another type of problem such as a bad motor. The board and control can also fail giving these problems. There are many things to check in addition to these. Hope this will help you get started.
Apr 05, 2013 | Taylor Ice Cream Makers
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
Ice Cream Makers Logo
389 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
